Mechanics Problem: Cart Velocity with Leaking Sand and Inclined Plane"
  • Thread starter Thread starter Trigger
    Mechanics
The discussion focuses on a mechanics problem involving a cart losing sand while being pulled horizontally and a box sliding down an inclined plane. The differential equation for the cart's velocity, given by F - kg = M dv/dt, accounts for the mass loss due to sand leaking at a constant rate k. When the force F is zero, the final velocity of the cart can be derived from the integrated equation V = (Ft + C)/M. Additionally, the equation of motion for the box on the incline is mg sin(A) - kg = (M + m) dV/dt, where m represents the remaining sand mass.
  • Understanding of Newton's Second Law of Motion
  • Familiarity with differential equations
  • Knowledge of basic mechanics concepts such as mass, force, and acceleration
  • Concept of mass flow rate in physics
  • Study the application of Newton's Second Law in variable mass systems
  • Learn about integrating differential equations in mechanics
  • Explore the dynamics of objects on inclined planes
  • Investigate the effects of mass loss on motion and acceleration
Students in mechanics courses, physics enthusiasts, and anyone interested in understanding the dynamics of variable mass systems and inclined motion.
Trigger
Please help me out with the following problem. I have only just begun a mechanics course and am finding it extremely difficult!
(a)A cart with initial mass M and a load of sand 1/2M loses its sand at the rate k kg/sec. the cart is puled horizontally by a force F. Find the differential equation for the rate of change of the cart's velocity v in terms of k, M and F while there is sand in the cart?
(b)Suppose F=0 and the cart's initial velocity is Vo. What is the sand's final velocity when all the sand has left the cart?
(c)A box is filled with sand and is sliding down a smooth plane. The sand is leaking out at a constant rate. If the plane's inclination is A, what is the equation of motion of the box plus all the sand?
Force= rate of change of momentum= d(mv)/dt
You probably know F= ma which is a special case when m is a constant.
In general F= d(mv)/dt= m(dv/dt)+ v(dm/dt).
(a) You are told that m starts out as (3/2)M but decreases at constant rate k:
m= (3/2)M- k and dm/dt= -k.
That means F= ((3/2)M-k)(dv/dt)- kv. That is the differential equation you want.
(b) Now take F= 0 and solve the differential equation for v(t). You will need to determine what t is when all the sand is gone.
(c) Almost the same as (b). The force directly downward is mg but you are on a plane with angle A. Can you find the "component of force" along the plane?
(a) To find the differential equation for the rate of change of the cart's velocity v, we can use Newton's Second Law, which states that the net force acting on an object is equal to its mass times its acceleration. In this case, the net force is the force F pulling the cart horizontally, minus the force of the sand leaking out, which is equal to the rate of change of the mass (k) times the acceleration due to gravity (g). So, the equation is:
F - kg = M dv/dt
(b) If F=0 and the cart's initial velocity is Vo, we can use the equation from part (a) and integrate it with respect to time to find the final velocity. The initial mass of the cart and sand is M + 1/2M = 3/2M, and since the sand is leaking out at a constant rate, the mass of the cart decreases at a constant rate as well. So, the equation becomes:
∫dV = ∫(F - k(3/2M))dt
Integrating both sides and solving for V, we get:
V = (Ft + C)/M
where C is the constant of integration. When all the sand has left the cart, the mass of the cart is just M, so the final velocity is:
Vf = (Ft + C)/M = (Ft + C)/M
(c) To find the equation of motion for the box plus all the sand, we can use the same approach as in part (a). The net force acting on the box and sand is the force of gravity pulling them down the incline, minus the force of the sand leaking out. So, the equation is:
where m is the mass of the sand remaining in the box at time t. We can also use the relationship between mass and volume to express m in terms of the density of the sand (ρ) and the volume of the box (V):
m = ρV
Substituting this into the equation, we get:
mg sin(A) - kρV = (M + ρV) dV/dt
This is the equation of motion for the box plus all the sand.
  • · Replies 21 ·
9K
  • · Replies 16 ·
