Is a bushing even needed at low loads and low rpm?
  • Thread starter Thread starter gulfcoastfella
    even Rpm
The discussion centers around the necessity of using a bushing in a low-load, low-RPM application involving a shaft submerged in lakewater. Participants explore various material options and configurations, considering the implications of using or not using a bushing in this specific context.
  • One participant questions the need for a bushing given the low loads (25 lbs radial, 17 lbs thrust) and very low RPM (1 rpm), suggesting that a larger shaft diameter could be beneficial.
  • Another participant proposes that if a bushing is not used, the polished shaft could directly sit in a polished hole, effectively making the shaft itself act as the bushing.
  • There is a suggestion to consider using plastic for the part with the hole, as metal on plastic is believed to be superior to metal on metal, although concerns about the durability of plastics in submerged applications are raised.
  • One participant shares their experience with low PV applications, indicating that the presence of water could provide sufficient lubrication, and suggests exploring plastics with low water absorption and added lubricants.
  • Questions are raised regarding the materials of the shaft and the hole, daily run-time, expected service life, and acceptable mean time between failures (MTBF), emphasizing the importance of bushing material being softer than the shaft to facilitate easier replacement.
  • A participant mentions that while some engineering texts caution against using plastics in submerged applications, specific materials like Teflon and iGlide bearings may be suitable for such conditions.
  • Another participant suggests historical alternatives like oil-soaked wood bearings, which were used in the past and are waterproof, indicating a potential low-maintenance solution.
The discussion contains multiple competing views regarding the necessity and material choice for bushings in this application. Participants express differing opinions on the effectiveness and durability of various materials, particularly plastics versus traditional bushings.
Participants express uncertainty about the long-term performance of plastics in submerged conditions and the implications of using a bushing versus a direct shaft-to-hole configuration. There are also unresolved questions about the specific materials and their properties in relation to the application.
gulfcoastfella
I've got a shaft that rotates at about 1 rpm and handles a radial load of approximately 25 lbs, a thrust load of 17 lbs, and a bending moment of about 150 lb-in. The shaft and joint will be submerged in lakewater. A shaft diameter of 1.5 in would be nice, but in general a larger shaft would be preferable to a smaller one. I was looking at bushing options, but I'm starting to wonder if I need a bushing of any kind at all (considering the low loads and very low rpm). It seems that a no-bushing solution would also go hand in hand with a larger shaft diameter.
If not a bushing then what?
The polished shaft would sit in a polished hole of the same diameter running through the support structure. Basically, the shaft itself would be the bushing.
Could you make the part with the hole in it out of plastic? Metal on plastic is much better than metal on metal. There are a lot of different plastics with fillers to improve lubricity. I'd check something like McMaster Carr if this is a 1-off.
I've read in several places that plastics, while good for humid and splashed applications, will break down when submerged for an extended period.
Isn't metal on metal essentially the makeup of a brass or steel bushing anyway?
Hi Gulf, My experience is in dry running applications with a high PV. Your application has a low PV and has water to 'lubricate' it, so the environment should be much more forgiving. Bushings might be bronze but they have lubricants and polymers to keep them from galling. Other bushings are straight plastic. Depending on the plastic, they should work very well especially in water where you gain some lubricity. I'd suggest looking for a plastic that has low water absorption and added lubricants such as oil, Teflon, molydisulfide, etc...
There is also bearing grade machinable bronze but personally, I'd try the plastic first.
What material is the shaft? What material is the "hole"? Daily run-time? Expected service life? What is your acceptable MTBF?
Generally speaking, bushing material is softer than the shaft, so any wear occurs on the bushing. Also, replacing a worn bushing is a much easier fix than replacing a shaft or repairing an elongated hole.
Thanks Q_Goest, that's some great advice. I had read in some engineering texts that plastic can break down in submerged applications, but I think they were speaking about plastics in general.
I've found that Teflon is generally able to run submerged, and I found a http://www.igus.com/wpck/default.aspx?pagenr=7103&C=US&L=en" offering iGlide bearings, some of which are rated for submerged application as well. This just goes to show that engineering texts are generalizations, and if you find someone who offers something out of the ordinary, then by all means use it if it applies.
That's a great point Pantaz.
  • · Replies 19 ·
30K
