Can 4^n always be greater than or equal to n^4 for n ≥ 5?
  • Thread starter Thread starter IntroAnalysis
    Proof
The discussion revolves around the inequality \(4^n \geq n^4\) for natural numbers \(n\) where \(n \geq 5\). Participants are exploring methods to prove this inequality, particularly through mathematical induction.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Some participants attempt to use mathematical induction, starting with a base case and then assuming the inequality holds for \(k\) to show it for \(k+1\). Others raise questions about how to manipulate the expressions involved, particularly in breaking down \( (k+1)^4 \) to compare it with \( 4(4^k) \).
There is ongoing exploration of different approaches, including differentiation and previous inequalities. Some participants have provided hints and guidance, while others are seeking clarification on specific steps or concepts. The discussion reflects a mix of attempts and suggestions without reaching a consensus.
Participants note the importance of not providing complete solutions, adhering to forum guidelines. There is also mention of previously established inequalities that may relate to the current problem.
IntroAnalysis
n is an element of the Natural numbers, and n [itex]\geq5[/itex], then 4^n [itex]\geq(n^4)[/itex]
Base case: n=5, then 4^5=1024 >or= 5^4=625 as required.
Inductive step, assume k is an element of Natural numbers and 4^k > or = k^4.
Then we must show 4^(k+1) > or = (K+1)^4
What's the trick to showing this?
Base case: n=5, then 4^5=1024 ≥ 5^4=625 as required.
Inductive step, assume k is an element of Natural numbers and 4^k ≥ k^4.
Then we must show 4^(k+1) ≥ (k+1)^4
1. The problem statement, all variables and given known data
What have you tried?
I know that 4^(k + 1) =4(4^k) which helps since we know 4^k >/ k^4,
But (k + 1)^4 = k^4 + 4k^3 + 6k^2 + 2k + 1, and I don't know how to break this up
to show 4(4^k) >/ k^4 + 4k^3 + 6k^2 + 2k + 1
Any hints?
Any hints?
RTP: 4n>n4 for all n≥5.
I'll skip the trivial n=5 case.
S(k): Assume; 4k>k4 for all k≥5.
S(k+1): RTP: 4k+1>(k+1)4
LHS=4k+1=4k*4>k4*4=4k4
Now consider; y=4x^4-(x+1)^4; Differentiate this and see what you can deduce for x≥5. Remember to restrict y after this to use on the induction. In restricting, change the domain and co-domain to an integer field.
shaon0,
Do you realize that you are not supposed to give complete solutions?
SammyS said:
shaon0,
Yeah, sorry. Uhm, just told by a mod. Deleting the post. Sorry. He's not online, so hopefully he hasn't seen it. I've deleted it and left a hint.
Actually, I think I found an easier solution. Can someone comment?
We previously proved that for all n >/5, 2^n> n^2. We proved 2^(n+1) > (n+1)^2.
Now since we know that 2 > 0 and n + 1 > 0 (since n >/5), we know that we can square both sides and the inequality still holds so: (2^(n + 1))^2 = 2^(2n + 2) = 2^[2*(n+1)]
=4^(n+1) > ((n+1)^2)^2 = (n+1)^4
Hence, we have 4^(n+1) > (n+1)^4 which is what we wanted to prove.
Yes, that's true but how would you have proven 2^n>n^2? As an extension; k^n>n^k for n,kEZ+
Base case n = 5: 2^n (= 32) > n^2 (=25) is true as required.
Now we assume that the statement is true for some n an element of Natural numbers, n[itex]\geq5,[/itex], and show that it must be true for n + 1. We know n2< 2n and therefore 2n2<2n+1.
We are now going to use that 2n + 1 < n2 which is true for all
n[itex]\geq5[/itex]:
2n + 1 < n2 implies n2+2n +1 < 2n2< 2n+1 and therefore (n + 1)2< 2n+1.
We are therefore done if we can demonstrate that 2n +1 < n2 for all n [itex]\geq5[/itex]. This inequality is equivalent to 2 < (n - 1)2. The right side
is strictly increasing function of n for n > 1, thus (n - 1)2>(5 - 1)2= 16 > 2 for all n [itex]\geq5[/itex]. This completes the proof of the original inequality.
By the way, what does RTP stand for?
So y = 4x4 - (x+1)4 = 4x4 - (x4 + 4x3 + 6x2 + 4x +1)
Then dy/dx = 12x3 -12x2 -12x -4 = 12x(x2-x -1) - 4
For x ≥ 5, (actually for x ≥ 2), dy/dx is positive. Thus, 4(x+1)must be greater than (x + 1)4. Is that it?
  • · Replies 18 ·
