Mn Catalyst for Asymmetric Epoxidation
  • Thread starter Thread starter gravenewworld
    Catalyst
The discussion focuses on the use of an Mn Catalyst for the asymmetric epoxidation of trans-B-methyl styrene, specifically addressing the determination of enantiomer presence through H NMR analysis. Participants highlight the importance of using chiral shift reagents, particularly lanthanide metals with chiral ligands, to differentiate between enantiomers by creating diastereomeric complexes that exhibit distinct NMR shifts. The calculation of enantiomeric excess (ee) is clarified as being derived from the integration of specific NMR signals, with an example provided where a mixture of 75% R and 25% S yields an ee of 50%. The Jacobsen-Mn system and the use of the chiral shift reagent Eu(hfc)3 are also referenced as key components in this process.
  • Understanding of asymmetric epoxidation reactions
  • Familiarity with H NMR spectroscopy
  • Knowledge of chiral shift reagents and their applications
  • Basic concepts of enantiomeric excess (ee) calculation
  • Research the Jacobsen-Mn system for asymmetric catalysis
  • Learn about the use of chiral shift reagents in NMR analysis
  • Study the integration techniques for calculating enantiomeric excess from NMR data
  • Explore the original Jacobsen paper on enantiomeric excess determination
Chemists, particularly those specializing in organic synthesis and stereochemistry, as well as students and researchers involved in asymmetric catalysis and NMR spectroscopy analysis.
gravenewworld
For lab we used an Mn Catalyst for epoxidation of trans-B-methyl styrene. One of the problems is that we have to figure out which enantiomer of the trans-B-methylstyrene epoxide is formed by looking at the H NMR. I have never looked at an NMR before to try to figure out which enantiomers were present. Does anyone know what I should look for in order to determine which enantiomers are present or at least a website that explains how to look at NMR for different enantiomers? Also, what is enantiomer excess (ee) and how can it be calculated from the NMR? Is it by integration?
Chemistry news on Phys.org
Enantiomeric excess is the excess of one enantiomer over the other. For example, say you had a mixture of enantiomers, 75% R and 25% S. The enantiomeric excess is the amount of chiral material beyond the amount of racemic material. In this case the ee would be 50%, meaning that 50% of the material is a racemic mixture and the other 50% is R only.
The most common way to do this by NMR is to add a "chiral shift reagent" to the NMR sample. These reagents are usually lanthanide metals with 2 or 3 chiral ligands. When your product complexes to the lanthanide, you will have diastereomeric complexes arising from the two enantiomers. Diasteremers often have significantly different NMR shifts. You can calculate the ee from the integration of a particular "diagnostic" NMR signal.
I assume that you used the Jacobsen-Mn system. In the original Jacobsen paper they determined ee's by using the chiral shift reagent Eu(hfc)3.
Reference: J. Am. Chem. Soc. 1991, 113, 7063-7064
AHHHH thank you very much, you hit the nail right on the head.
  • · Replies 19 ·
11K
