Homework SolutionSolving x^4-5x^2+4: Why & How
  • Thread starter Thread starter mindauggas
    Factoring
The discussion revolves around the polynomial equation x^4 - 5x^2 + 4, with participants exploring different methods of factoring and solving it. The subject area includes polynomial algebra and factoring techniques.
  • Mixed
  • Participants discuss the original poster's attempt to factor the polynomial using a difference of squares approach and question the validity of that method. Others suggest that recognizing the quadratic form of the polynomial may lead to a more straightforward solution.
Some participants have provided insights into the factoring process, noting that the polynomial can be expressed in terms of its quadratic components. There is an acknowledgment of different approaches being explored, but no explicit consensus has been reached.
There is a mention of the original poster's confusion regarding the steps taken and the desired outcome of the factorization. The discussion includes references to specific algebraic identities and methods without resolving the underlying assumptions or constraints.
mindauggas
(1)Why can't I solve [itex]x^{4}-5x^{2}+4[/itex]
in the following way:
[itex](x^{4}-4x^{2}+4)-x^{2}[/itex]
[itex](x^{2}-2-x^{2})(x^{2}-2+x^{2})[/itex]
If there is any reason why..
(2)How to solve it if the answer to get is [itex](x-1)(x+1)(x-2)(x+2)[/itex] ?
Solved ... sorry to bother
It looks like you're trying to set this up as a difference of squares, a2 - b2 = (a + b)(a - b).
That will work here, as x4 - 4x2 + 4 is a perfect square, namely (x2 -2)2.
So the above would factor into ((x2 -2)) -x)((x2 -2)) + x)
= (x2 -x - 2)(x2 + x - 2)
= (x - 2)(x + 1)(x + 2)(x - 1).
As you can see, this works, but it is probably more difficult than factoring x4 - 5x2 + 4 directly, realizing that it is quadratic in form.
x4 - 5x2 + 4 = (x2 - 4)(x2 - 1). Each of these two factors can be broken into two linear factors.
You need to further factor each quadratic trinomial:
[tex] x^2 \mp x + 2[/tex]
