HHow do I solve this integral using substitution?
The discussion revolves around solving the integral \(\int\frac{dx}{\sqrt{x(1-x)}}\) using substitution, specifically with the substitution \(u=\sqrt{x}\). Participants are exploring the conversion of the integral into terms of \(u\) and addressing the challenges that arise during this process.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the substitution \(u=\sqrt{x}\) and its implications for transforming the integral. There are attempts to express \(dx\) and \(1-x\) in terms of \(u\). Some participants express confusion about the conversion process and question the validity of proposed solutions.
The discussion is ongoing, with various participants offering differing opinions on the correctness of proposed solutions. Some guidance has been provided regarding the substitution and manipulation of the integral, but no consensus has been reached on the final answer.
Participants are required to use the substitution method as part of their homework, which may limit the approaches they can take. There is also mention of external tools like Maple providing a solution, which raises questions about the accuracy of manual calculations.
bross7
I'm stuck on how to advance further on this problem and if anyone can point my in the right direction I would be greatly appreciative.
[tex]\int\frac{dx}{\sqrt{x(1-x)}}[/tex]
The integral has to be solved using substitution, but we are required to use
[tex]u=\sqrt{x}[/tex]
From this:
[tex]du=\frac{dx}{2\sqrt{x}}[/tex]
But I am stuck on how to convert the remaining portion of the function in terms of du.
[tex]\int\frac{dx}{u\sqrt{1-x}}[/tex]
I gave it a try and couldn't get anywhere with it. Maple says the answer is arcsin(2x-1).
Is that exactly how the question was given?
[tex]u = \sqrt{x}[/tex]
so
[tex]u^2 = x[/tex]
and
[tex]2du = \frac{dx}{\sqrt{x}}[/tex]
First use the third equation, then use the second equation to get rid of any other instances of x that're left.
And Shawn is not correct in his solution.
--J
Shaun's solution looks good to me, what do you propose the actual answer is Justin?
Complete the square within the square root in the denominator and the apply the result
[tex]\int\frac{dx}{\sqrt{a^2-x^2}} = arcsin\frac{x}{a}[/tex]
spacetime
www.geocities.com/physics_all
[tex]\int\frac{dx}{\sqrt{x(1-x)}} = 2 \arcsin{\left(\sqrt{x}\right)}[/tex]
Differentiate it and you'll get the integrand.
The derivative of arcsin(2x-1) is [tex]\frac{2}{\sqrt{4x^2 - 4x + 2}}[/tex].
--J
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 25 ·
