What Would Happen If Negative Mass Existed?
The discussion explores the hypothetical implications of negative mass existing alongside normal mass, particularly in gravitational interactions and thermodynamic properties. Participants examine various scenarios, including the behavior of celestial bodies and the nature of exotic matter.
  • Some participants propose that a negative mass moon could orbit the Earth, while others challenge this by suggesting that the gravitational interaction would be repulsive, pushing the moon away.
  • One participant notes that if the Moon had negative mass and the Earth had positive mass, the Moon would accelerate towards the Earth due to the repulsive force acting on the negative mass.
  • Another participant discusses the implications of two bodies with equal but opposite mass, suggesting they would maintain their separation while accelerating away from each other, raising questions about kinetic energy conservation.
  • Concerns are raised about the thermodynamic properties of gases made from negative mass, with one participant mentioning that such gases could have negative temperatures, leading to a runaway energy situation when interacting with normal matter.
  • References to literature on negative mass and related concepts are provided, including a historical article from 1957 and a link to a resource discussing negative temperature.
Participants express differing views on the gravitational behavior of negative mass and its implications, indicating that multiple competing perspectives remain unresolved throughout the discussion.
Participants highlight limitations in understanding the implications of negative mass, including the need for precise conditions to maintain balance between positive and negative masses and the complexities of energy conservation in these scenarios.
Brane Dead
Anyone tried to imagine a world with negative mass? A mixed world of normal mass and negative mass does not seem so bad in the sense that a negative mass moon would surprisingly still orbit the earth! Might be problems in making atoms though...
Negative mass has been discussed in the physics literature. Some describe the accelerating expansion of the universe to be due to negative mass (and that mass is called "cosmological constant" matter or "dark energy").
There was a well known article on this subject published back in 1957
"Negative Mass in General Relativity," H. Bondi, Reviews of Modern Physics, Vol. 29 ,No. 3, pp 423-428 (1957)
Pete
If the Moon had a negative mass, but the Earth a positive one, then the force of gravity between them would be a repulsive one - the Moon would be pushed farther and farther away. I don't see why the O.P. said it would still orbit - unless he meant that the Earth would have a negative mass as well.
The force would be repulsive, but acting on a negative mass it would accelerate the moon towards the Earth.
Hmmmm... I get it. But it would still push the Earth away from the moon. Right?
In fact this leads to a seeming absurdity. If two bodies had no initial relative velocity, then the negative mass one would fall towards the positive mass, while the positive mass would 'fall' away from the negative one.
If the two masses had the same magnitude, but opposite signs, they would maintain their initial separation, while accelerating away across the universe.
Right.
Yes, but of course their total kinetic energy would remain zero, (since their total mass would be zero).
I had a look on the web and found the following page on this subject
http://www.concentric.net/~pvb/negmass.html
Yes, though you would need perfect balance to keep one object from accelerating more than the other. As others have pointed out, both momentum and energy are conserved, because the positive energy and momentum of the positive mass is exactly balanced by the negative energy and momentum of the negative mass.
There are more/similar absurdities in sight, though. Gas made out of negative mass matter (usually called exotic matter) would have a negative temperature. This would mean, thermodynamically, that a gas made out of exotic matter interacting with a gas made out of normal matter would lead to a runaway situation - the gas with the normal matter would gain a large amount of positive energy, the gas with the exotic matter would gain a large amount of negative energy.
See for instance the sci.physics.faq on negative temperature
here
(it doesn't talk about negative mass, just negative temperature).
For a while I thought this situation meant that negative mass would violate the second law of thermodynamics, but that's not quite right. It does lead to the runaway situation I described, but this sort of runaway doesn't violate the second law, if you read the fine print...
  • · Replies 0 ·
