| New Reply |
diffraction of sound |
Share Thread | Thread Tools |
| Nov8-11, 08:51 AM | #1 |
When the wavelength is bigger than an obstacle, then the sound waves bend around the obstacle.
so why I can't imagine this at all I read this page and watched the animations of it but it doesn't tell me the answer http://www.acoustics.salford.ac.uk/f...s/diffract.htm reflection of sound takes place when the difference in the speed of the sound between two media is great,while refraction takes place when the difference in the speed of the sound between two media is small why??? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov8-11, 09:37 AM | #2 |
I think you are trying to categorise things too much. Diffraction always happens, at any boundary*. It is just more noticeable for a 'small' object.
Also, the effect of diffraction at the boundary between two 'transmissive' media will produce both a reflected wave and a refracted wave. The amount of reflection and refraction will depend on how big a change there is across the boundary and the angles involved. * diffraction is just the result of all the waves adding up across the whole of the wavefront. When you shine light through a pinhole the resulting shape of the wave that gets through is very rounded. When you shine it through a doorway, much more light, in total, gets through but a tiny amount also 'leaks round the sides' with a very similar pattern at the very edge (90degrees) as from a pinhole. When we discuss reflection and refraction, we are usually discussing very wide wavefronts (big apertures) so we just ignore the off-axis ('diffracted') wave because it is so insignificant compared with all the energy going in the classically defined 'ray' direction. But, for telescopes, for instance, we have refraction effects (focusing the image) plus diffraction effects (the ultimate blurriness of pictures of the Moon's surface etc.). |
| Nov8-11, 07:15 PM | #3 |
Okay,how about my second question?
| Nov8-11, 08:11 PM | #4 |
| Nov9-11, 05:48 PM | #5 |
| Nov14-11, 06:15 AM | #6 |
Actually,I'm very confused about that
so what makes waves encounter more relection when difference in the speed of sound between air and water is big? Another question : [img] http://hyperphysics.phy-astr.gsu.edu...mgsou/difr.gif [/img] My problem about diffraction is here what does we mean by "the wavelengths of sound are long enough to bend around the post" Thanks in advance |
| New Reply |
| Thread Tools | |
Similar Threads for: diffraction of sound
| Diffraction: how to know the amount of slits from a diffraction pattern? | Introductory Physics Homework | 0 | ||
| diffraction grating (missing diffraction beam) | Introductory Physics Homework | 4 | ||
| Simple single-slit sound diffraction | Introductory Physics Homework | 4 | ||
| diffraction grating problem, missing orders, diffraction minimum and maximums. | Introductory Physics Homework | 1 | ||
| Diffraction of sound waves | Advanced Physics Homework | 1 | ||
