Configuration Space In Classical Mechanics: Definition
The discussion centers on the concept of Configuration Space in classical mechanics, specifically the dimensionality defined by generalized coordinates. The professor states that for a system of N particles, the configuration space is 3N-k dimensional, where k represents holonomic constraints. This contrasts with other sources that suggest a simpler n-dimensional configuration space based solely on generalized coordinates. The confusion arises from differing definitions of n and N, leading to misunderstandings about the dimensionality and representation of configuration space in graphical form.
  • Understanding of generalized coordinates in classical mechanics
  • Familiarity with degrees of freedom in mechanical systems
  • Knowledge of holonomic constraints and their impact on dimensionality
  • Basic graphing skills for multidimensional spaces
  • Study Hamilton's Variational Principle in detail
  • Explore the concept of degrees of freedom in mechanical systems
  • Review the differences between holonomic and non-holonomic constraints
  • Investigate graphical representations of multidimensional spaces in physics
Students and educators in classical mechanics, physicists exploring multidimensional systems, and anyone seeking clarity on the concept of configuration space and its applications in mechanics.
Dr_Pill
Hi,
I'm a bit confused wit the concept Configuration Space.
First, the professor defined generalised coordinates as such:
U got a system of n particles, each particle has 3 coordinates(x,y,z), so u got 3n degrees of freedom.
If the system has k holonomic constraints, u got 3n-k degrees of freedom.
Instead of working with cartesian coordinates, we now define a new set of coordinates q1,q2,..,q3n-k.
These are the generalised coordinates of the system,3n-k in total.
I get this.
Then a little bit further, when explaining Hamilton's Variatonal Principle, he defines a Configuration Space.
"The configuration space of a system is a 3n-k dimensional space with the generalised coordinates on the coordinate-axes."
So far, so good.
On the reference list of this course,Classical Mechanics of Goldstein is listed.
First page of the second chapter of Goldstein:
This n-dimensional space is therefore known as the configuration space...
In classical mechanics from Kibble, I didn't even found such thing as config space.
Also, on the internet I've found another course of Classical Mechanics:
http://www.phys.ttu.edu/~huang24/Teaching/Phys5306/CH2A.pdf"
There they say
Meaning of “motion of system between time t1 and t2”:
• A system is characterized by n generalized coordinates
q1,q2,q3,..qn.
• At time t1: q1(t1),q2(t1),..,qn(t1) represent a point in the ndimensional
• As time goes on, the system point moves in configuration
space tracing out a curve, called the
path of motion of the system.
• At time t2: q1(t2),q2(t2),.. ,qn(t2)
represent another point in the ndimensional
Here they say n generalised coordinates in n dimensional space, not like according to my professor 3n-k dimensions with 3n-k generalised coordinates!
Also, there's a little graph with on the horizontal axis q1 and on the vertical axis q2, but there are n dimension, according to their course !
But for the axes only q1 and q2 is used, so why not qn-1 and qn.
But a graph with only two axis, is 2-dimensional right?
It is not ndimensional
See my frustration here?
Please help me.
The dimensionality of configuration space is always equal to the number of degrees of freedom. The references you've cited are just using the symbol n to denote different things. Your professor is describing N particles moving in three dimensions with k holonomic constraints, so the number of degrees of freedom is n = 3N - k.
I thought so myself.My professor made some mistakes, he used little n instead big N for the particles, very confusing at first.
Now is it clear, thanks :)
Edit:
Still not 100% clear:
Given is a simple graph of the configuration space with the generalised coordinates q1 and q2 on the axes, this is only 2-dimensional right, that I don't get?
Why put only those generalised coordinates on the axes? Is it equivalent to a simple x and y axes?
I need this to define the path of motion of the system.
U define a system that has N particles, so N generalised coordinates.But system has 3N-K dimensions, so u need 3N-k axes, and this is impossible to plot?
This is the simple graph below, I found it on the net.It is from Texas University.
