Why Do Electric Fields Move from Positive to Negative Charges?
The discussion centers around understanding electric fields, their behavior between charges, and related concepts such as magnetic fields and the application of the right-hand rule in vector diagrams. Participants explore theoretical aspects, equations, and practical applications, including questions about specific scenarios in capacitors and the behavior of moving charges.
  • One participant expresses difficulty in understanding electric fields and questions whether the electric field vector moves from positive to negative charges in capacitors as well.
  • Another participant cautions that the equation for electric force assumes the charge is stationary, noting that moving charges involve additional considerations with magnetic fields.
  • A participant mentions using the left-hand rule for determining the direction of magnetic force, despite it being traditionally associated with current-carrying conductors, and questions its applicability to velocity-magnetic field diagrams.
  • There is a discussion about the right-hand rule for determining magnetic force direction, with links provided for further clarification.
  • One participant seeks an explanation for the directional behavior of magnetic forces, indicating a lack of understanding of the underlying reasons.
Participants express varying levels of understanding and confusion regarding electric and magnetic fields. There is no consensus on the application of the left-hand rule versus the right-hand rule, and the discussion remains unresolved regarding the reasoning behind the direction of magnetic forces.
Participants reference various equations and concepts without fully resolving the assumptions or conditions under which they apply, particularly regarding the behavior of moving charges and the rules for determining force directions.
devious_
I need help understanding electric fields. I basically suck at answering questions related to them (I get 95% of them wrong :cry:).
What I do know about them is:
The electric field vector moves from a positive charge (+q) to a negative charge (-q). (Is this the same case in a capacitor? I saw the vector pointing for -q to q through the dielectric of two plates.)
I also know a few equations:
[tex]E=\frac{F}{q}=k\frac{Q}{r²}[/tex]
[tex]\Delta U_{e} = -\Delta W_e = - Fd = -Eqr[/tex]
[tex]W = kqQ (\frac{r_{a}-r_{b}}{r_{a}r_{b}})[/tex]
[tex]\Delta U_{e} = k\frac{qQ}{r}[/tex]
[tex]\Delta V = \Delta \frac{U_{e}}{q} = k\frac{Q}{r}[/tex]
[tex]\Delta V = \frac{\Delta W_{e}}{q} = \frac{Fd}{q} = \frac{Eq}{q}d = Ed[/tex]
[tex]\Delta V = \frac{q}{C}[/tex]
[tex]C = \frac{\epsilon_{0}A}{d}[/tex]
I appologize if this is the wrong forum.
Your request is rather broad, to say the least. :smile:
I presume you have a textbook? And have attempted to solve problems?
If you have specific conceptual questions, feel free to ask them in this forum. But if you need help in solving problems, post them in the appropriate homework help forum--you'll get loads of help. Be sure to show your work--that's the only way we can pinpoint exactly where your confusions lie.
If you need a site to browse to get a different take on electric fields than your textbook may provide, a good place to start is here: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elefie.html#c1 (Poke around on that site and you will find most, if not all, of the equations you listed explained.)
Always be cautious with this relation. It is assumed that when this relation is applied that the charge is stationary. If the charge is moving then F is given by
F = q(E + vxB)
and in this case E does not equal F/q.
Pete
pmb_phy said:
F = q(E + vxB)
Just to make it clear, vxB here is the cross product of v and B.
Thanks for the link Doc_Al. I went and got a better textbook, because I found out mine sucked. I think I understand electric fields alright now. :smile:
And pmb_phy: if the charge is moving, then it has a magnetic field, correct?
Speaking of magnetic fields, I have a question:
If you are given one of those V-B-F vector diagrams, for example one with the vector lines of velocity (b) and field strength (v) and were asked to find the direction of the magnetic force. The book suggests that I use the right-hand rule, but it's kind of difficult to apply it, so I used the left-hand rule and it worked on all questions. I read that the left-hand rule was specifically meant for I-B-F vector diagrams, but can I also used it for V-B-F diagrams too, or was that a fluke?
edit: V = charge's velocity
Correct.
I can't say unless I know exactly what you're doing since it seems that you're doing something wrong. The left hand rule will give the wrong result so all I can say without further info is that your'e applying it incorretly.
Pete
I'm using my thumb to point in the direction of the magnetic force, my index finger to point in the direction of magnetic flux, and using my remaining fingers (or palm) to point in the direction of current/velocity.
right hand rule
Here are two links that may help with the right hand rule:
http://www.physics.brocku.ca/faculty/sternin/120/slides/rh-rule.html
http://physics.syr.edu/courses/video/RightHandRule/
This is what I don't get: just because your hand is made the way it is, the magnetic force moves that way? My teacher never gave me an explanation for the reason WHY the magnetic force moves the way it does.
  • · Replies 29 ·
