Heat loss rate directionality/sign convention
The problem involves calculating the heat-loss rate through a concrete slab floor of a house, given the interior and ground temperatures. The subject area is thermodynamics, specifically heat transfer and conduction.
  • The original poster attempts to apply the heat transfer equation but questions the sign convention used in the calculation. Some participants raise concerns about the coordinate system and the interpretation of temperature differences.
Participants are exploring the implications of sign conventions in heat transfer calculations. There is a recognition of the need for clarity regarding the direction of heat flow and the interpretation of the results. Some guidance is offered regarding common sense in understanding heat flow direction.
There is a mention of potential confusion regarding the units used in the thermal conductivity value and the implications of the sign in the heat-loss rate calculation. The original poster expresses uncertainty about acceptable answers in an exam context.
adammw111
An 8.0m by 12m house is built on a concrete slab 23cm thick. What is the heat-loss rate through the floor if the interior is at 20°C while the ground is at 10°C?
[itex]H=-k A \frac{\Delta T}{\Delta x}[/itex]
kconcrete = 1.0 W / m K (approx)
[itex]H=\frac{-1.0 (8 * 12) (10-20)}{0.23} = 4.17[/itex] kW
My problem is that the book (Essential University Physics, Wolfson) has the answer as -4.17 kW, but that would imply that heat is being transferred from the ground to the house, which it clearly cannot be from the temperature of the house being larger than the ground's temperature.
I usually have problems with the sign of this value of H, how do I know what direction they are asking for by "through" an object - it could be either. Would either value be acceptable in an exam?
Thanks.
Are you sure the sign on delta X is positive? What is your coordinate system for the horizontal slab? Is x=0 the 10 or 20 C surface?
First of all you have given K to be 1.0W/mK. which means 1000W/K to be used in the equation . This gives the answer to the equation to be 4.17kW.
As to which direction, heat flows from hot to cold.
Sometimes worrying about the signs that crop up in equations can be confusing... they are never 'wrong' but don't forget common sense.
Sorry! My mistake, mK is correct I misread it as milliKelvin and not as m.K
Ignore my previous response
  • · Replies 16 ·
