Determining a function from deriv, func in integral
  • Context: Graduate
  • Thread starter Thread starter nobahar
    Function Integral
This discussion centers on solving a differential equation represented as \(\frac{d}{dt}(f(t)) = A g(t) h(t) - B f(t)\). The user seeks assistance in determining the function \(f(t)\) over time, utilizing integration techniques and the concept of an integrating factor. The solution involves finding the integrating factor \(u(t) = e^{Bt}\) to transform the equation into an exact differential, leading to the expression \(f(t) = e^{-Bt}\int_a^t e^{Bz}g(z)h(z)dz\). The conversation highlights the importance of correctly applying integration limits and understanding the implications of initial conditions.
  • Understanding of differential equations, specifically first-order linear equations.
  • Familiarity with integration techniques and the concept of integrating factors.
  • Knowledge of functions and their properties, particularly in relation to time-dependent variables.
  • Proficiency in using LaTeX for mathematical expressions.
  • Study the method of integrating factors in first-order linear differential equations.
  • Explore the application of Laplace transforms for solving differential equations.
  • Learn about the implications of initial conditions in differential equations.
  • Practice writing and interpreting mathematical expressions in LaTeX.
Mathematicians, engineers, and students studying differential equations, particularly those interested in time-dependent functions and their applications in modeling dynamic systems.
nobahar
Hello!
I have a value which changes over time, I think I can represent this as f(t). It increases by an amount determined by two other values which also change with t: g(t) and h(t), all multiplied by a constant: A. It decreases by an amount determined by its value at the given time: f(t), multiplied by some constant: B.
So I figured:
[tex]\frac{d}{dt}(f(t)) = A g(t) h(t) - B f(t)[/tex]
So the value of the function at time = t1 is:
[tex]\int_{0}^{t_{1}}\frac{d}{dt}(f(t)) dt = A \int_{0}^{t_{1}} g(t) h(t) dt - B \int_{0}^{t_{1}}f(t) dt[/tex]
This gives f(t1) - f(t), f(t) in this case = 0, and so it gives f(t1).
[tex]f(t1) = A \int_{0}^{t_{1}} g(t) h(t) dt - B \int_{0}^{t_{1}}f(t) dt[/tex]
However, the second component on the RHS says that the integral of f(t) dt from 0 to t1 is required. The value of t at a given time between 0 and t1, say t = a, is given by the equation above, evaluated from 0 to a. Therefore:
[tex]f(t1) = A \int_{0}^{t_{1}} g(t) h(t) dt - B \int_{0}^{t_{1}}(A \int_{0}^{t_{1}} g(t) h(t) dt - B \int_{0}^{t_{1}}f(t) dt) dt[/tex]
Does that even make sense?
I'm stuck! Help!
Thanks in advance!
nobahar said:
Hello!
So I figured:
If I understand what you are saying this should be
[tex]f(t1) = A \int_{0}^{t_{1}} g(t) h(t) dt - B \int_{0}^{t_{1}}(A \int_{0}^{t} g(z) h(z) dz - B \int_{0}^{t}f(z) dz) dt[/tex]
That is, the inner integral is from 0 to t, and gives a function of t to be integrated again.
I'm stuck! Help!
Thanks in advance!
I don't see how that helps you at all! If you are trying to solve the differential equation,
[tex]\frac{df}{dx}+ Bf= Ag(t)h(t)[/tex]
then you need to find an "integrating factor". That is a function, u(t), such that multiplying the entire equation by it makes the left side an "exact differential"- that is
[tex]\frac{duf}{dt}= u\frac{df}{dt}+ Buf= Au(t)g(t)h(t)[/tex]
Once you have that, integrating on both sides gives
[tex]u(t)f(t)= A\int u(t)g(t)h(t)dt[/tex]
To find the integrating factor, use the product rule for the derivative:
[tex]\frac{duf}{dt}= u\frac{df}{dt}+ \frac{du}{dt}f= u\frac{df}{dt}+ Buf[/tex]
so we must have du/dt= Bu. Since B is a constant, that is easy to solve: [itex]u(t)= e^{Bt}[/itex].
That is, multiplying by [itex]e^{Bt}[/itex] makes the equation
[tex]e^{Bt}\frac{df}{dt}+ Be^{Bt}= \frac{e^{Bt}f}{dt}= Ae^{Bt}g(t)h(t)[/tex]
and, integrating,
[tex]e^{Bt}f(t)= A\int e^{Bt}g(t)h(t)dt[/tex]
so that
[tex]f(t)= e^{-Bt}\int_a^t e^{Bz}g(z)h(z)dz[/tex]
where I have changed the "dummy" variable of integration on the right so you will not accidently "cancel" the two exponentials. The upper limit is t so the right hand side is a function of t. You can take the lower limit to be whatever is convenient. Changing it just changes the constant of integration.
and, integrating,
so that
Thanks for all the help, it's much appreciated.
I am slightly confused, however.
When integrating:
[tex]\frac{d}{dt}(u(t)f(t)) = A u(t)g(t)h(t)[/tex]
If u(a)f(a) = 0, where a is the lower bound, then I can see why we can divide by u(t). However, if it doesn't, then we can't divide both sides by u(t), since f(b)u(b) - f(a)u(a), the difference from the definite integral, with b the upper bound, is the difference of different, non-zero products. Is this correct? Also, since u(t) can't = 0 (i.e. it's never zero), then f(a) has to equal zero.
I can attempt to write it in latex if necessary! I hope it makes sense.
Thanks in advance.
  • · Replies 0 ·
