How Much Force to Keep Foam Underwater?
The discussion revolves around a problem involving a block of foam plastic submerged in water, specifically focusing on the force required to keep it underwater. The problem includes parameters such as the volume and density of the foam, as well as the density of water.
  • Participants explore the calculation of mass from volume and density, discuss buoyancy effects, and question the relationship between the weight of the foam and the buoyant force acting on it. There are attempts to derive equations related to the forces involved.
Participants are actively engaging with the problem, sharing different methods of calculation and questioning assumptions. Some guidance has been offered regarding the buoyant force and the weight of the foam, but there is no explicit consensus on the final approach or solution.
There is mention of potential confusion regarding the application of Archimedes' principle and the need to account for both the weight of the foam and the buoyant force when submerged. Participants express uncertainty about the formulas and calculations involved.
ChunkymonkeyI
A block of foam plastic has a volume of 25.0 cm^3 and a density of 0.800 g/cm^3. How large a force is required to hold it under water?
F=mg, m=density times volume
I first converted 25.0 cm^3 into 2.5 times 10^-5m^3 and .800 g/cm^3 into 800 kg/m^3
Then I used the formula m=density times volume
m=(density)(volume)
m=(800 kg/m^3)(2.5 times 10^-5 m^3)
m=0.02 kg
Then I used the formula F=mg and plugged 0.02 kg for the mass and 9.80 m/s^2 as g and multiply them together to get 0.196N but Ik the answer is suppose to be .0490 and Idk what I'm doing wrong can someone help me. Maybe I didn't think about the density of water or something like that
Why didn't you just multiply the volume of 25 cc by the density of .8 g/cc to get the mass of the foam? You can always convert g to kg by moving the decimal point.
Yes, if you wish to submerge the foam block, you must account of the buoyancy produced when the block is pushed and held under the water.
Idk what 2 do from there because I tried using Fb=density of fluid times volume of fluid times g and its still not getting me the right answer
Compute the weight of object. Compute weight of equal volume of water. Subtract them and you get 0.049 N.
How do I compute the weight of equal volume because Idk what formula ur referring 2
You multiply the volume of the object by the density of water. Density of water is 1000 kg/m^3. Then convert to weight in Newtons.
Thank u very much but just wondering do u know a way 2 dervive an equation for this type of problem in order to find the force required so that time is saved?
Sure but you should be able to do that. To solve for the force to hold the object under water you computed the buoyant force as
Fb = density water * volume * gravity constant
To determine the weight of object
W = density of object * volume * gravity constant
Do the above equations suggest anything to you? Hints: common terms, factoring...
Signing off for the day.
I think I got it but just 2 be on the safe side...
In each equation u factor out Vg so now we have
Equation 1:Fb=Vg(Density of water)
Equation 2:Weight of object or Fw=Vg(density of object)
Combinding them we get Fg/density of water=Fw/Density of object
Weight of object the same as Fw which is Fweight?
But if the object isn't moving should'nt it mean ƩF = 0 → buoyancy = mg ?? Why should we subtract them?
You must subtract them because the object you are holding under water has some weight itself. If it has too much weight, it sinks due to its own weight. Draw a free body diagram of a motionless body under water and place arrows on it denoting the forces on the object. How many forces are there?
Have you heard of Archimedes principle?
