New Reply
Rotation of a Rigid Object around a fixed axis
Share Thread Thread Tools
Nov13-11, 04:01 AM   #1
K.S
As a result of friction, the angular speed of a wheel changes with time according to
dθ/dt = ω_o*e(-σt)
where ω_o and σ are constants. The angular speed changes from 3.50 rad/s at t=0 to 2.00 rad/s at t=9.30s.
(a) Use the information to determine σ and ω_o. Then determine
(b) the magnitude of the angular acceleration at t=3.00s,
(c) the number of revolutions the wheel makes in the first 2.50s, and
(d) the number of revolutions it makes before coming to rest.
Now, I can get part (a) to (c) - my answers are:
(a) ω_o = 3.50; σ=0.0602
(b) -0.176 rad/s^2
(c) 1.29 revs
However, I have in part (d) the expression
ω_o*e(-σt) = 0 ,
but I find there is no way I can get an answer from this expression, since ln0 is undefined.
Can anyone enlighten me please? Thanks in advance!
Source: Physics for Scientists and Engineers with modern physics, 8th edition, Serway and Jewett, page 318
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov13-11, 06:02 AM   #2
Recognitions:
Gold Membership Gold Member
You are correct that the angular speed as defined in this problem never reaches zero, but the question relates to the angular position θ. Perhaps if you look at the expression for θ it will be more obvious what to do.
Nov13-11, 06:10 AM   #3
Mentor
Quote by K.S View Post
ω_o*e(-σt) = 0 ,
What are you trying to do with this expression?
Nov13-11, 06:31 AM   #4
K.S
Filip Larsen, I did as you have suggested, and I obtained
θ = ω_o/σ (1 - e(-σt)) , when I integrated ω from t=0 to t=t
Now I have the variable t which i had attempted to find from the expression ω_o*e(-σt).
Doc Al, I had wanted to find the time t when the wheel comes to rest - or as I had interpreted as when angular speed becomes zero.
Inferring from your reactions, I think there is something gravely wrong with the assumption that angular speed becomes zero when the wheel comes to a rest? Sorry all, it does seem my foundation is a little shaky. :x
Nov13-11, 06:40 AM   #5
Mentor
As Filip points out, it never does come to rest. (It's an exponentially decreasing function.) But that won't stop you from finding the angle traveled through. So what should be the time when it comes to rest? (That will give you your limits of integration for finding the angle.)
No, that's what coming to rest means. Nothing wrong with that!
Nov13-11, 06:58 AM   #6
K.S
Oh god, thanks Doc Al! You're a lifesaver. Okay I got it, and I did so by finding
lim->inf ω_o/σ (1 - e(-σt)) = ω_o/σ
Thanks Filip Larsen for the help too!
Nov13-11, 07:02 AM   #7
Recognitions:
I obtained θ = ω_o/σ (1 - e(-σt)) , when I integrated ω from t=0 to t=t
In your expression for θ above, what happens when t goes to infinity?
There is nothing wrong as such. You can calculate the position angle of the wheel when it comes to rest, even if "when" here means after infinitely long time. You should probably think of this problem more of an exercise in mathematical concepts (e.g. limits) than you should consider it an example of a physically accurate model.
New Reply
Tags
angular, introductory physics, serway
Thread Tools
Similar Threads for: Rotation of a Rigid Object around a fixed axis
Thread Forum Replies
Rotation of a Rigid Object About a Fixed Axis Introductory Physics Homework 1
Rotation of a Rigid Object about a fixed axis Introductory Physics Homework 1
Rotation about a fixed axis Introductory Physics Homework 7
Rotation about a fixed axis Introductory Physics Homework 8
