How Can I Store and Print Specific Decimal Digits of Pi Using MATLAB?
  • Context: MATLAB
  • Thread starter Thread starter phil.st
    Pi
The discussion focuses on storing and printing specific decimal digits of Pi using MATLAB, specifically from the 9901st to the 10000th digit. The user employs the Brent-Salamin algorithm within a custom function called agm_pi(d) to compute Pi to a specified number of decimal places. However, they encounter limitations due to MATLAB's default double-precision floating-point representation, which restricts precision to about 16 significant figures. The conversation highlights the need for alternative approaches to handle high-precision calculations beyond this limit.
  • Familiarity with MATLAB programming
  • Understanding of the Brent-Salamin algorithm for Pi calculation
  • Knowledge of variable-precision arithmetic (VPA) in MATLAB
  • Awareness of floating-point representation and its limitations
  • Research the vpa function in MATLAB for variable-precision arithmetic
  • Explore alternative algorithms for high-precision Pi calculation, such as the Gauss-Legendre algorithm
  • Learn about MATLAB's array handling capabilities for large vectors
  • Investigate libraries or toolboxes that extend MATLAB's numerical precision
This discussion is beneficial for MATLAB programmers, mathematicians, and anyone interested in high-precision numerical computations, particularly those working with mathematical constants like Pi.
phil.st
Hi! I'm using MATLAB and I want to store or print some particular decimal digits of pi, from 9901 to 10000. I'm using the algorithm below (Brent-Salamin algorithm) to print the first 10000 digits but I can't find out a way to save and print only the decimal digits from 9901 to 10000. What function can I use? Any ideas?
Code:
 function P = agm_pi(d)
% AGM_PI  Arithmetic-geometric mean for pi.
% Brent-Salamin algorithm.
% agm_pi(d) produces d decimal digits.
% See Cleve's Corner, "Computing Pi",
% http://www.mathworks.com/company/ ...
%    newsletters/news_notes/2011/
% Copyright 2011 MathWorks, Inc.
digits(d)
a = vpa(1,d);
b = 1/sqrt(vpa(2,d));
s = 1/vpa(4,d);
p = 1;
n = ceil(log2(d));
for k = 1:n
   c = (a+b)/2;
   b = sqrt(a*b);
   s = s - p*(c-a)^2;
   p = 2*p;
   a = c;
end
P = a^2/s;
http://en.wikipedia.org/wiki/Gauss–Legendre_algorithm
Well, MATLAB by default represents numbers as double-precision floating points:
http://www.mathworks.com/help/techdoc/matlab_prog/f2-12135.html
That means that you only have 53 bits for your fraction (in decimal terms, about 16 significant figures):
http://en.wikipedia.org/wiki/Double_precision
You can see where the problem arises when you try to calculate beyond 16 decimal places using the implementation provided (and no, you can't try to do something sneaky like multiplying the answer by 10^16!)
I had a similar problem as a homework assignment in undergrad once (and I suspect that this is something similar)--the above insight provided the critical hint that I needed to come up with a solution, and may do the same for you.
HINT: how big can you make a vector (1 x n, or n x1 array) in MATLAB?
9K
9K
