Can Laurent-Puiseux series be computed for annular regions?
  • Context: Graduate
  • Thread starter Thread starter jackmell
    Series
The discussion centers on computing the Laurent-Puiseux series for the function f(z)=√(z(z-1)(z-2)) in annular regions, specifically for 1<|z|<2. The initial series expansion is successfully derived for the unit disc |z|<1, utilizing a differential equation with polynomial coefficients and a root c=1/2 for fractional powers. The main inquiry is whether similar techniques can be applied to generate the series in the specified annular region, with suggestions for variable substitutions such as z ↦ 1/z or z ↦ 1 ± z to facilitate the process.
  • Understanding of Laurent series and their applications
  • Familiarity with differential equations and power series
  • Knowledge of complex analysis, particularly annular regions
  • Experience with variable substitutions in mathematical functions
  • Research methods for computing Laurent-Puiseux series in annular regions
  • Explore variable substitution techniques in complex analysis
  • Study differential equations with polynomial coefficients
  • Investigate examples of functions with known Laurent series in annular domains
Mathematicians, particularly those specializing in complex analysis, students studying advanced calculus, and researchers exploring series expansions in annular regions.
jackmell
For example, consider:
[tex]f(z)=\sqrt{z(z-1)(z-2)}[/tex]
It's easy to compute the Laurent-Puiseux series in the unit disc, up to the singular point at z=1:
[tex]f(z)=\sqrt{2} \sqrt{z}-\frac{3 z^{3/2}}{2 \sqrt{2}}-\frac{z^{5/2}}{16 \sqrt{2}}-\frac{3 z^{7/2}}{64 \sqrt{2}}-\frac{37 z^{9/2}}{1024 \sqrt{2}}+\cdots,\quad |z|<1[/tex]
That's done by creating a differential equation for the function with polynomial coefficients then solving it using power series where in this case, the indical equation has a root c=1/2 to generate the fractional powers.
But can we generate a Laurent-Puiseux series for the function in the annular region [itex]1<|z|<2[/itex]?
I haven't found any info on the net about this and was hoping someone here could shed some light on the matter.
Thanks,
Jack
Not sure whether it will work here, but variable substitutions like ##z \longmapsto \dfrac{1}{z}## or ##z \longmapsto 1 \pm z## often help.
12K
