Proof of ab=0 <--> (a=0 or b=0) without Division
  • Context: Undergrad
  • Thread starter Thread starter Bartholomew
    Division Proof
The discussion centers around proving the statement a*b=0 if and only if a=0 or b=0 without using division. Participants explore the implications of this property in various mathematical contexts, particularly within discrete mathematics and the properties of integers and rings.
  • Some participants assert that the property a*b=0 implies a=0 or b=0 is not universally true across all number systems, suggesting it holds only in systems that allow division.
  • Others argue that divisibility is a fundamental property of multiplication and that avoiding division can prevent assumptions about the existence of certain numbers.
  • One participant proposes using the properties of positive and negative integers to approach the proof without division, questioning whether this requires implicit assumptions.
  • Another participant emphasizes that the proof's validity depends on the axioms and definitions of the integers being used, particularly regarding their ordering and properties as an integral domain.
  • Some participants highlight that the discussion of integers must consider their definition and properties, such as the Peano axioms, to establish the proof's foundation.
  • There is a suggestion that the proof of a*b=0 implies a=0 or b=0 is trivial if one assumes the integers are an integral domain, as this would mean there are no zero divisors.
Participants express differing views on whether the proof can be established without division, with some asserting that it cannot be done in general while others suggest it may be possible under certain conditions. The discussion remains unresolved regarding the necessity of division in the proof.
Participants note that the property may not hold in certain rings, such as Z mod 4, and emphasize the importance of the definitions and axioms being used in the discussion.
This discussion may be of interest to students and educators in discrete mathematics, algebra, and those exploring foundational properties of integers and rings.
Bartholomew
Is there a proof of a*b=0 <--> (a=0 or b=0) that does NOT involve division? Also, my discrete math professor has claimed that mathematicians tend to avoid the concept of division. How accurate is this claim for discrete mathematicians? What is the reason for it?
exceptionally accurate. Divisibilty is a property of multiplication.
x divides y if there is a z such that xz=y
Avoid dividing numbers unnecessarily - it avoids supposing things ought to exist that may not exist.
For instance the "correct" thing to say is something like 2x=3 has no solution in Z because 2 does not divide 3. DO NOT write... because 3/2 is not in Z. What is 3/2? What if the ring weren't Z? Your proof relies on the existence of some larger object (the raionals) which you've not proved even exist in a meaningful way, and it precludes your answer being applied in other rings where there is no obious embedding into something that behaves like the rationals.
As for the proof ab=0 => a or b =0, in what space are you thinking? Z, R? C? In Z we may assume that if niether a nor b is zero they are both positive. But 0<a<=ab is one of the axioms of Z with ordering, which is a contradiction.
no. this property is not always true for all numbers systems. it is true if and only if the number system can be extended to one allowing division. so this property is an axiom. after making the axiom, one can prove there is a larger number system in which division by non zero numbers is possible. conversely, if there is such an extension, then thios property must have held.
we also tend to avoid driveby shootings. what is he talking about? maybe he means that we, like many other human beings, find fractions hard. hence the first step in any problem involving fractions is always to "multiply out the botoms".
In any ring, such as the real numbers, rational numebrs integers, etc,:
0b = (a + (-a))b = ab + (-a)b
add ab
ab + (-a)b + ab = (a + (-a) + a)b = ab
therfeore by identity 0b = 0.
A simlair proof holds for left mulplication by zero.
he asked the converse too, jcsd. i.e. to prove that ab cannot be zero unless a or b is zero. you did the easy direction.
OOps I didn't see that, in that case I should of added then that a*b = 0 implies that either a or b is zero is only true in rings that are integral domains (which obviously includes all the rings I mentioned but not rings in general).
which was my point, i.e. a ring is an integral domain if and only if it can be embedded in a field, i.e. a ring where division is available. hence essentially the proof cannot be done without division.
Thanks for your replies. I actually am only interested in the ab=0 --> (a=0 or b=0) direction. The problem came up as part of a proof about integers. Could you approach it by saying that if a and b are both not 0, then each must be positive or negative, and for each case use the multiplication rules that pos * pos = pos, neg * pos = neg, and so on? Or would that require a lot of implicit assumptions?
But anyway, without actually having such a proof in hand... let me see if I understand the situation. The proof of ab=0 --> (a=0 or b=0) does NOT require division explicitly, but for it to work it must be part of a system where division is an option--so you might as well use division anyway since then the proof is easy. Is that right?
Anyway, is it safe to say that mathematicians use division fairly freely when they are working with the REAL numbers? (To hedge my bet, include applied mathematicians too)
a proof uses whatever is eprmitted. so to do this proof you use whatever you know about integers. so what are you given? are you given that the rpoduct of positives is positive?
if so you can prove the product of negatives is positive and the product of one of each is negative. that would do it. on the other ahnd maybe you are explicitly given that the product of non zero factors is non zero. or maybe you are given that the rationals exist. but actulaly you cannot prove the rationals existm until you know that the rpooduct of non zero integers is non zero. so if you do not show us what axioms you have for the integers we cannot tell you what is mneeded for a proof.
i.e. proof is a relaitve thing. it depends on what you already know. and we do not know that.
for example you can deduce that the product of two positive integers is positive, from the analogous property for sums, and induction, as follows:
let a be positive, then a(1) = a is also positive. if ad is positive for all positive integers d less thasn n then an = a(n-1+1) = a((n-1)+a, which is a positive integer a(n-1) plus another positive integer a. this is positive if i know that the sum of two positive integers is positive. so do you know that?
you see I cannot do it without knowing what you are given.
the point is one cannot prove anmything about the integers until one knows what definition o=f the integers you are using. so i mthoiught i would consult some of my books and give you a typicsal dfinition of the integers. to my surprize the only one i could find at hand thjat even defiens them is artin's algebra book, who gives p[eanos axioms.
he says the positive integers are a set S equipped with a "successor' function f:S-->S (intuitively taking n to n+1), such that f is injective, there is a special integer 1 which is not the successor of any other, and if T is any subset of S such that it contains 1 and also contains the successor of every one of its elements then T = S.
he thens proves a few of the various proeprties of integers and elaves to us to prove that if ab=ac then b=c, which is equivalent to what tyou want.
the key to this is as i sketched above, using the injectivity of the successor function. i.e. you never get the same answer twice by adding more ones to a given integer.
but to repeat: before you can do this proof, you must ask what is the definition of integers you are using.
^^^ commutative^^^ ring
I'm not actually _given_ anything--this isn't an assigned question and the course I am taking is sadly not that rigorous anyway. But the proof I am looking for, if it exists, must not use division or any assumption which would normally be derived through the use of division. The integers I'm working with would be ... -2, -1, 0, 1, 2, ... although I don't know just how a formal definition of that should go.
You have to use some of the formal properties of the integers, such as the ordering on them, since the result isn't true in Z mod 4, for instance. I gave you the answer: if a and b are positive, which we may assume, then ab>0
Are you sure that you don't need division to show that a>0 and b>0 --> ab>0 from basic premises?
The ordering is part of the integers, it comes for free - there are other rings which have division but do not have an ordering (eg the complex numbers). Put it interms of peano axioms if you must, but all I'm doing is using the fact that if a and b are positive integers, then ab=>a. OK? The ordering is deducible from the basic axioms without need to define division at all.
So where does the integers being an integral domain come in at all?
If you assume they are an integral domain then by definition there are no zero divisors, and the question is trivial, as you are asking us to prove it is an integral domain.
Okay, I think I understand now. Thanks for your help.
  • · Replies 47 ·
