Capacitors - what does same potential mean?
The discussion clarifies that "same potential" in capacitors means that there is no voltage difference between the two plates. When a capacitor is fully discharged, both plates are at the same electric potential, indicating no electric field exists between them. If one plate has a positive charge and the other has an equal negative charge, they are not at the same potential, as this creates an electric field. Understanding electric potential is crucial for grasping the behavior of capacitors in electrical circuits.
  • Understanding of electric potential and voltage
  • Basic knowledge of capacitor operation
  • Familiarity with electric fields and charge distribution
  • Concept of charge conservation in capacitors
  • Research the relationship between electric potential and electric fields in capacitors
  • Study the principles of charge distribution in capacitors
  • Learn about the implications of voltage differences in circuit design
  • Explore the mathematical equations governing capacitors, such as Q = CV
Students studying electrical engineering, educators teaching physics concepts, and anyone interested in understanding capacitor functionality and electric potential principles.
logearav
Capacitors -- what does same potential mean?
Revered members,
When the capacitor is fully discharged, the plates of capacitor are at same potential.
I want to know the interpretation of the term same potential.
Does it mean both the plates having the same charge, that is either + or - ? And the other possibility is if one plate is having 6C(say) of + charge, the other plate has 6C of negative charge. Thanks in advance, members
It means that the two plates have the same electric potential. Electric potential is a specific physical quantity with a specific definition that you are probably meant to know already. If you don't know about it, then I recommend that you look it up:
http://en.wikipedia.org/wiki/Electric_potential
In any case, if the two plates are at the same potential, then there is no difference in potential between them. We call the difference in potential between two points the "voltage" between those two points. So, saying that there is no difference in potential between the two plates is the same as saying that there is no voltage between them.
For a capacitor with +6 C on one plate and -6 C on the other plate, the two plates would most certainly NOT be at the same potential. The charge would give rise to an electric field. An electric field points in the direction in which the electric potential decreases the most steeply. So if the potential were the same everywhere in a region of space (i.e. there are no gradients in the potential), then there would be no electric field in that region. If you have a field, you must have a potential difference, and vice versa.
  • · Replies 18 ·
