How does the twin paradox work in a circular orbit?
The discussion centers around the twin paradox as it applies to a thought experiment involving a rocket in a circular orbit around the Earth. Participants explore the implications of time dilation in this scenario, particularly at low relativistic speeds. The conversation touches on theoretical aspects of special relativity and general relativity, as well as the effects of gravity and acceleration on time perception.
  • One participant proposes a scenario where a rocket achieves a circular orbit and travels at low relativistic speeds, suggesting that the person on the rocket would age less than someone on Earth.
  • Another participant agrees with this understanding, linking time dilation to curvature and gravity, but invites corrections to their interpretation.
  • Some participants discuss the necessity of calculations to determine the effects of time dilation in this context, with one expressing uncertainty about the appropriate equations to use.
  • There is mention of the effects of Earth's gravity on time dilation, with a participant noting that velocity must be sufficient to offset gravitational effects for the aging difference to hold true.
  • A hypothetical scenario is introduced where the experiment is moved to an asteroid or an imaginary point in space, suggesting that the conclusions may still apply.
  • One participant describes a more complex thought experiment involving multiple clocks in different states of motion and gravitational influence, highlighting unexpected results in time elapsed among them.
  • Another participant recalls the time dilation experienced by GPS satellites, noting the interplay of velocity and gravitational effects on their aging relative to Earth clocks.
Participants generally agree on the basic premise of time dilation in the context of the twin paradox but express differing views on the specifics of calculations and the influence of gravitational effects. The discussion remains unresolved regarding the precise conditions under which the aging differences occur.
Some participants express uncertainty about the mathematical calculations required to analyze the scenario, indicating a reliance on further research or clarification of concepts. Additionally, the discussion includes assumptions about the effects of gravity and velocity that may not be universally accepted.
phinds
Insights Author
Dearly Missed
There have been a couple of posts over the last few months that posit a relativistic-speed path in a circle around the Earth and I want to make sure I correctly understand the ramifications. It's the twin paradox in a circle. SO ... here's a scenario that I think will solidify it for me:
This is a thought experiment, not something that would be practical, but it is remotely within the realm of physical possibility.
Rocket achieves Earth orbit and then with a massive waste of fuel accelerates in the circular orbit to very low relativistic speeds (say .001c), and then decelerates in the orbit and returns to earth.
The person on the craft would be slightly younger than the one on earth, yes? I don't care if it's fractions of a second or what, just the absolute fact.
That is, the end result is exactly the same as if the craft had accelerated away from Earth and then it had turned around and came back (which is in essence what it IS doing).
Space news on Phys.org
Thats entirely correct as I understand it.
My understanding is time dilation is directly related to curvature, curvature is intrinsically linked to gravity and geometry: acceleration can be used to "create" curvature and therefore time dilation.
Any corrections to my understanding are welcome.
Well, first, I think your question is more appropriate for the SR-GR forum than for the Cosmology forum.
Second, you can answer this by yourself by doing some simple calculations.
I suspect that if I could do the calculation, I would not have needed to ask the question.
I've read lots of your posts, and from those I believe that you're quite capable of doing the calculations that will answer your question.
EDIT: Though you might have to look something up. Everybody has to do this from time to time.
Oh, I might be able to do the math, but first I'd have to know what math to DO, and I don't.
Phinds, that would only be correct if the velocity is high enough to offset the reduced effect of Earth's gravity on time dilation. GPS satellites are slower than Earth based clocks by 7 microseconds per day due to time dilation caused by their velocity, however they are FASTER by 45 microseconds per day due to being further away from Earth. Combined the two effects cause satellite clocks to be faster by 38 microseconds per day. AKA they age faster by 38 microseconds per day than those of us on Earth do.
OK so move the experiment to a location around a nominal mass asteroid. Or an imaginary point in space.
Exactly!
Whether wrt the Earth or an asteroid or an imaginary point in space, I'm pretty sure, without doing the calculations because, yeah, I'm lazy, that a traveller moving at .001c away from and then back to the Earth or an asteroid or an imaginary point in space will have aged less than a person on either the Earth or an asteroid or occupying an imaginary point in space, respectively.
My point to Phinds was that by doing a few actual calculations, then he can answer lots of these sorts of questions for himself, more or less intuitively.
As to the deeper question of what, physically, causes differential aging. Who knows? Superficially, it suggests that what we refer to as empty space isn't empty. And, as Cosmo Novice suggested, acceleration/deceleration seems to be affecting (producing changes in) the periods/frequencies of oscillators that are accelerating/decelerating.
I think he addressed this adequately by pointing out that he does not know which equations he would apply and how, even if he is able to do the calculations once he has them.
The analysis of circular motion does contain some surprises.
George Jones said:
Consider a spherical planet of uniform density and five clocks (changing notation slightly):
clock A is thrown straight up from the surface and returns to the surface;
clock B is dropped from rest through a tunnel that goes through the centre of the planet;
Clock C remains on the surface;
clock D remains at the centre of the planet;
clock E orbits the body right at the surface.
Assume that A is thrown at the same time that B is dropped, and that the initial velocity of A is such that A and B arrive simultaneously back at the starting point. The times elapsed on the clocks A, B, and C between when they are all are together at the start and when they are all together at the end satisfy [itex]t_A > t_C > t_B[/itex].
Since A and B are freely falling and C is accelerated, it might be expected that [itex]t_A > t_C[/itex] and [itex]t_B > t_C[/itex], so [itex]t_C > t_B[/itex] seems strange.
Assume that clock E is coincident with clocks A, B, and C when A and B start out. As Fredrik has noted, unless the density of the planet has a specific value, E will not be coincident with with A, B, and C when A and B arrive back, but E will be coincident again with C at some other event. The elapsed times between coincidence events of E and C satisfy [itex]T_C > T_E[/itex]. Again, since E is freely falling and C is accelerated, this seems strange.
THanks for reminding me of that. I WAS aware of it, but didn't think about it in this instance. I often don't connect the dots between various facts that I am aware of. Probably comes from (1) only doing this stuff casually, (2) not remembering all of them all of the time, and (3) ... uh ... I forget.
I guarantee you that he has the ability to find the proper equations and do the calculations on his own. He was just being a bit lazy, and I called him on it. That's all.
While I admire your defending him, I don't see any problem with requiring him to do a bit of homework.
If you want some examples of extreme laziness, then just look at some of my posts. :smile:
Anyway, bottom line, we all, including now Phinds I think, know the answer to his question. The really deep, intriguing question concerns, at least for me, the physical nature of relativistic differential aging.
EDIT: And, thanks to George Jones for presenting a nice complication.
Me either.
I think you nailed it. I'm pretty sure that I've forgotten a lot (most?) of the physics I learned many years ago, but I can't be sure. :smile:
Anyway, keep asking questions. I think we both find this stuff fascinating, and are thankful for the science advisors and mentors who donate their time to help us better understand what physics can tell us about our world.
And, I apologize if I in any way offended you. My replies weren't meant to do that. As I mentioned, I've read many of your posts, and from those I think you are a thoughtful and intelligent person.
  • · Replies 43 ·
  • · Replies 24 ·
  • · Replies 31 ·
  • · Replies 48 ·
  • · Replies 19 ·
  • · Replies 19 ·
