How may signals travel through a cable without interfernce?
The discussion centers on how different signals can travel through a cable without interfering with each other, focusing on concepts such as interference, multiplexing techniques, and the nature of digital versus analogue signals. Participants explore both theoretical and practical aspects of signal transmission in electrical engineering.
  • One participant inquires about the mechanisms that allow signals to be differentiated in a cable without interference.
  • Another participant explains that signals can be separated using Frequency Division Multiplexing (FDM) and Time Division Multiplexing (TDM), noting the importance of bandwidth in handling rapid signal changes.
  • A different participant introduces the concept of orthogonal frequencies, suggesting that they do not interfere with each other, and references Orthogonal Frequency Division Multiplexing (OFDM) as a related technique.
  • Some participants argue that modern digital communication systems, while robust, ultimately rely on complex analogue signals at the transmission level, particularly in the context of Quadrature Amplitude Modulation (QAM).
  • There is a discussion about the efficiency of analogue systems compared to digital systems, with one participant highlighting the redundancy in analogue transmissions and the cleverness of modern coding and modulation techniques.
Participants express differing views on the nature of digital versus analogue signals, with some asserting that modern digital systems are fundamentally analogue at the transmission level. There is no consensus on the implications of this distinction or the overall efficiency of the systems discussed.
Participants mention various technical terms and concepts, such as multiplexing techniques and modulation strategies, without fully resolving the complexities or assumptions underlying these discussions. The conversation reflects a range of expertise and familiarity with the subject matter.
Individuals interested in electrical engineering, telecommunications, signal processing, and the theoretical underpinnings of digital and analogue communication systems may find this discussion relevant.
waqarrashid33
I am an Electrical Engineering.I want to ask that how different signals move in a cable without effecting each other..e.g interference etc..
I am not strictly speaking about it interfence but how at the end we can differentiate these signals and get one of our need.
To avoid interference (crosstalk) signals need to be separated in some way. They can be 'carried' on radio frequency carriers using different frequencies (just like the channels on broadcast radio and TV). This is how it used to be done on old fashioned transatlantic telephone and satellite systems. You basically have a set of low power transmitters and a set of receivers at each end of the cable. There is a limit to how close the channels can be spaced (in frequency) due to one signal getting into another receiver filter.
This is nowadays referred to as Frequency Division Multiplexing. You can also (and this sounds really bizarre) use Time Division Multiplexing in which you switch very rapidly and regularly between a number of signals at the send end and then each receiver gets just one of the signals by looking at the appropriate times, getting a fast string of pulses (samples) of the wanted signal. You don't get anything for nothing, however. Your cable needs to be able to handle all these fast changes due to the switching so it needs to have a wide bandwidth capability.
These days, of course, digital signals are all mixed together (multiplexed) and interleaved in all sorts of ways so that no one sees the unwanted data - just their own. But, once you get to the level of the actual signal going down the pipe, you are again effectively dealing with a very complex analogue signal which has to be looked after and protected from interference and noise in a similar way. It is said that digital signals are robust and impervious to noise and interference. This is true up to a certain level, after which it goes with a bang (frozen frame on satellite TV etc.). Old fashioned radio and telephony are always subject to interference but they tend to 'die more gracefully' as the noise and interference increase - you can hear and understand stuff that just isn't pleasant to listen to but the info can still get through. Digital systems can handle vastly more useful information than simple analogue systems, though.
They spend millions of quids on getting systems that will reliably carry as much info as possible. And we use it for conversations like this plus the millions of other (less worthy) messages that tear around the Planet.
Correct me if I am wrong as I am no expert in communication and modulation, I just join in. Look up orthogonal frequencies which is frequencies that is different in a multiple of an integer, they do not interfere with each other. This is because if you look at the sinc pulse of each frequency, each frequency lies at the zero crossing of the other and has no interaction with the other or something. I read this like 8 years ago. Look up OFDM ( orthogonal frequency division multiplexing), they explain this much better than me. Also you can find the explanation in Fourier Series expansion.
The modern digital communication link is nothing digital about it! Look at the QAM stuff, it is a mix of two orthogonal frequencies ( 90 deg out of phase) to map each bit in a two dimension plane ( like xy plane) depend on the amplitude of each signal. When you get the QAM 256, each signal is detect and categorized into 8 different levels and this become analog, nothing digital about it.
Hence my remark in the middle of my last post " But, once you get to the level of the actual signal going down the pipe, you are again effectively dealing with a very complex analogue signal "
I restrained myself from spouting any more, waiting until the OP came back with some feedback about the level of answer he needed. I think too much info can scare people off. And we don't want that, do we?
I reply to your post actually to support your statement that it is nothing digital about the modulation. The only thing good about this over pure analog communication is they have check sum, request to resent if error detected. But like you said, the communication can get slow and all of a sudden just complete failure with funny screen and all.
It's quite amazing just how inefficient a straight analogue system is. Every analogue TV frame of a still shot is repeated endlessly, with the same information again and again. No wonder they can fit a dozen or more channels into the existing spectrum used by a single analogue channel.
The combination of coding and modulation is very clever these days - and there's still a lot of juice left in that lemon, apparently. More channels and better noise performance.
I was amused to read your "request to resend" statement (a telecoms strategy). As an ex broadcaster, that seems, to me, like a real luxury!
Don't quote me 100%, yes I said that because of the telecom, every serial communication I've seen have some sort of provision of check sum and request to resent. That to me is a very strong point to make the system more robust. Just when the signal degrades, the communication will get slower and slower and more and more delay.
Nice work when you can get it. In broadcasting, you have to plan a one way channel. Real pain.
  • · Replies 30 ·
  • · Replies 22 ·
