Conservation of Angular Momentum
The discussion revolves around a physics problem involving the conservation of angular momentum in a system of three uniform circular disks connected by strings. Participants explore the relationship between the angular momentum of the largest and smallest disks, considering their radii, densities, and rotational speeds.
  • Homework-related
  • One participant presents a formula for the ratio of angular momentum between the largest and smallest disks: \frac {L_C}{L_B} = \frac {R_A R_C}{R_B^2}.
  • Another participant notes that the angular momentum of each disk can be expressed as L = I \omega and emphasizes the importance of the same tangential speed for disks connected by strings.
  • This second participant mentions that their answer differs from the first participant's and suggests that the ratio will depend on the radius of the hub, indicating that multiple factors influence the outcome.
  • A participant acknowledges a mistake in their earlier expression and expresses a lighthearted attitude towards the discussion.
Participants do not reach a consensus on the correct expression for the ratio of angular momentum, indicating that multiple competing views remain regarding the problem's solution.
There are unresolved aspects related to the dependence on the hub radius and the assumptions regarding the disks' properties, such as density and thickness.
murphy
I have a physics problem that I think is not so hard but I just can't get the answer. There are two uniform circular disks that are rotating and attached by a string. there is no slip between the string and the disks. On the small disk is a hub that is attached like the first two to an even smaller disk by string. The radii are given for the three disks and the hub, and the smallest disk and largest disk have equal densities and thickness. I am asked to find the ratio between the magnitude of the angular momentum of the biggest disk to the angular momentum of the smallest disk. All the disks are spinning in the same direction. I added a picture of this but I'm not sure how exactly so it might not show. I appresciate any help I can get with this!
I get
[tex]\frac {L_C}{L_B} = \frac {R_A R_C}{R_B^2}[/tex]
on my first runthrough.
The angular momentum of each disk is [itex]L = I \omega[/itex]. Disks connected by strings will have the same tangential speed ([itex]v = \omega R[/itex]); use that fact to relate the angular speeds of the connected disks.
My answer differs from Tide's. ([itex]L_C/L_B[/itex] will depend on the hub radius, for one thing.) But I think you can figure it out for yourself. (Why should Tide and I have all the fun? :smile: )
Al,
You're right - I mistyped my expression off my notepad but we'll let Murphy figure it out! :-)
Thanks! I love this forum!
  • · Replies 16 ·
  • · Replies 36 ·
16K
