Chemical Engineering vs Nanotechnology Engineering/ Nanoengineering?
The discussion revolves around the comparison between undergraduate programs in Chemical Engineering and Nanotechnology Engineering (or Nanoengineering). Participants are exploring the differences, potential career paths, and the adaptability of each field.
  • One participant seeks advice on the differences and pros and cons of Chemical Engineering versus Nanotechnology Engineering.
  • Another participant suggests that Chemical Engineering is adaptable and allows for research or work in nanotechnology, even at the graduate level.
  • A participant provides a brief explanation of nanoparticles, noting their unique properties and potential applications across various fields.
  • One participant believes that a degree in Chemical Engineering can lead to opportunities in nanotechnology, indicating the diversity of the field.
Participants express differing views on the distinctiveness and adaptability of the two fields, with no clear consensus on which program may be superior or more beneficial.
Some assumptions about career paths and the nature of the programs are not fully explored, and there is a lack of specific examples of undergraduate programs in Nanotechnology Engineering.
Students considering undergraduate degrees in Chemical Engineering or Nanotechnology Engineering, as well as those interested in the applications of nanotechnology in various fields.
bublik13
Help me decide, by suggesting differences and weighing pros and cons of each undergraduate program. I'm in frantic need of help here, and all replies would be appreciated :P
what do you want to do with your degree?
chemical is pretty adaptable, and you can still do research / work in nano. . . even in grad school. tbh, I've never even seen a school offer an undergrad degree in nano.
Understand Nano technology
Nanoparticles are particles that have one dimension that is 100 nanometers or less in size.The properties of many conventional materials change when formed from nanoparticles. This is typically because nanoparticles have a greater surface area per weight than larger particles; this causes them to be more reactive to certain other molecules.
Nanoparticles are used, or being evaluated for use, in many fields. The list below introduces many of the uses under development. You can use the links in each paragraph to go to a detailed explanation.
I believe you can work in nanotechnology with a degree in Chemical Engineering. It's a diverse field. I'm similarly looking to get a degree in Chemical, but work more in the Energy related field.
  • · Replies 21 ·
