| New Reply |
Heat Equation - Trouble Finding a General Solution |
Share Thread |
| Nov19-11, 12:22 AM | #1 |
Solve: Ut=kUxx U(x,0)=e^3x 2. Relevant equations The Heat Equation: ![]() 3. The attempt at a solution g(y) in the heat equation for this problem is e^3y. I'm having serious trouble solving this because my professor hasn't taught us the method, and it isn't in the book. I've considered trying a change of variables by taking z=x-y, but this has led me to nowhere. I am lost, and I am not just fishing for a result. I actually want to know how to solve this damn thing. There's a few pages worth of **** in my notebook, and now I need some guidance. Thank you for your time. |
| Nov19-11, 02:38 PM | #2 |
The integral that you have to do is known as a Gaussian integral. A standard result, explained, for example, at http://en.wikipedia.org/wiki/Gaussian_integral is
[itex] \int_{-\infty}^\infty \exp\left( - A u^2\right) du = \sqrt{\frac{\pi}{A}}.~~~(1)[/itex] In your case, you must integrate [itex] \int_{-\infty}^\infty \exp\left( - \frac{(x-y)^2}{4kt} + 3y \right) dy.[/itex] The technique needed is known as "completing the square," namely we attempt to write the quadratic expression in [itex]y[/itex] as a sum of a square plus a constant term: [itex] -A y^2 + B y + C = -a (y+b)^2 + c . ~~~(2)[/itex] Here, [itex]a,b,c[/itex] will possibly be functions of [itex]x,t,k[/itex], but do not depend on [itex]y[/itex], so the resulting integral can be done by substituting [itex] u = y +b [/itex] and then using the formula (1). You should probably start with equation (2) and determine [itex]a,b,c[/itex] in terms of [itex] A, B,C[/itex]. |
| Nov21-11, 09:11 AM | #3 |
I just wanted to let you know that I haven't given up on the problem and am still working at it.
I'll be back with results whenever I solve it. |
| Nov21-11, 10:52 AM | #4 |
Thank you so much for your help. I reached the final solution. I'll upload the results to show you as soon as I can.
I have a final question as to what happened with a negative sign when I did a substitution, if you don't mind. |
| New Reply |
| Tags |
| heat equation, heat kernel, pde, poisson |
Similar discussions for: Heat Equation - Trouble Finding a General Solution
| Finding an implicit, general solution to a homogeonous differential equation | Calculus & Beyond Homework | 1 | ||
| 1D Heat equation, numerical solution with ONLY one heat source | Classical Physics | 1 | ||
| Finding the general solution to a differential equation | Calculus & Beyond Homework | 3 | ||
| Trouble finding velocity equation | Introductory Physics Homework | 2 | ||
| Finding a general solution to an equation | Precalculus Mathematics Homework | 6 | ||
