Baseball Velocity and Components: Solving for Final Velocity and Height
  • Thread starter Thread starter Tycho
    Stupid
The problem involves a baseball struck by a bat, which is caught 30 meters away after 3 seconds. The questions focus on determining the final velocity, launch angle, maximum height, and the X and Y components of the initial velocity. The original poster expresses uncertainty about the initial speed of the baseball.
  • Participants discuss using the distance and time to find the initial velocity components. Some suggest using kinematic equations, while others question the assumption of the initial speed being 10 m/s and propose considering higher speeds based on typical baseball velocities.
There is an ongoing exploration of the problem with various approaches being suggested. Some participants provide insights into calculating the initial velocity based on the time of flight and distance, while others highlight the need to reconsider the initial speed assumption.
Participants note that air resistance is being ignored, and there is a suggestion that the ball's actual flight distance exceeds the horizontal distance due to its trajectory.
Tycho
I'm not quite sure how to get started on this problem...
a baseball is struck by a bat, and 3 seconds later it is caught 30m away.
now the questions ask for it's final velocity, it's angle as it left the bat, the greatest height it reached, and the X and Y components of it's velocity as it was hit.
all of these things i can do if i had the speed of the ball initially. is it safe to assume that it is traveling at 10 m/s?
to find the X component of the initial velocity use v=d/t for the whole loop. To find the Y component of the initial velocity use V(final)-V(initial)=gt for half of the loop. I said half of the loop because you're looking at the velocity when the ball goes up in the air so that would take 1.5 seconds and on top the velocity is 0. After that, use vector addition to find the initial starting velocity and the angle.
I took a look at this website:
http://www.baseball-almanac.com/articles/fastest-pitcher-in-baseball.shtml
There is a list of the fastest pitchers in baseball. The speed range is 100-103 mph. So, let's consider a 100 mph pitch. We have
[tex]100 \frac{\mbox{miles}}{\mbox{hour}} \left( \frac{1,609.3 \mbox{ m}}{1 \mbox{ mile}} \right) \left( \frac{1 \mbox{ hour}}{3600 \mbox{ s}} \right) \approx 44.7 \frac{\mbox{m}}{\mbox{s}}[/tex]
You're probably safe with [tex]v_i \leq 44.7 \frac{\mbox{m}}{\mbox{s}}[/tex].
A [tex]10 \frac{\mbox{m}}{\mbox{s}}[/tex] pitch is slow, but you can use it.
If you take advantage of the fact that you know how long it flew, you should be able to determine the intial speed of the ball. In fact, since you're ignoring air resistance, it's the same as the final speed.
Perhaps you can figure out what the horizonal component of the ball's inital velocity.
P.S. Since the ball goes up and down during it's flight, it's traveling more than 30 meters. Since it's traveling more than 30 meters in 3 seconds, it's got to have started with a speed of more than 30 meters per second.
