How to erase pen writing by chemical?
  • Thread starter Thread starter scilover89
    Chemical Writing
Erasing pen writing can be challenging due to the permanence of certain inks. Common methods include liquid paper and sand rubber, but these can be messy and damaging to paper. Blue pen ink contains ferum tannate, which can be discolored using specific chemicals. Commercial products like Tipp-ex(R), which contains a white coating compound dissolved in trichloroethane, provide a cleaner solution for covering mistakes and allow for rewriting shortly after application.
  • Understanding of ink chemistry, specifically ferum tannate.
  • Familiarity with chemical solvents such as trichloroethane.
  • Knowledge of commercial correction products like Tipp-ex(R).
  • Basic skills in handling writing instruments and correction methods.
  • Research the chemical properties of ferum tannate and its interaction with solvents.
  • Explore alternative ink removal methods for different surfaces, including glass and plastic.
  • Investigate the formulation and application techniques of Tipp-ex(R) and similar products.
  • Learn about the environmental impact of using volatile solvents in correction products.
This discussion is beneficial for students, educators, and office workers who frequently use pens and require effective methods for correcting writing errors without damaging paper.
scilover89
Pen is a common tool for writing, but it is difficult to erase them if errors occur.
There's some ways to erase the pen writing, such as liquid paper and sand rubber. However, using liquid paper is not really tidy, while sand rubber might make a hole in your paper! :smile:
I heard that blue pen ink contain ferum tannate, so what chemical can be used to discolour the ink?
Chemistry news on Phys.org
Most ways will be messy since most methods are of liquid form. There are ways of removing such marks (even of permanent markers) if you had written them on a beaker...paper just won't do.
There are commercial products like Tipp-ex(R), in which a white coating compound is dissolved in trichloroethane, which is quite volatile to immobilize this compound on surfaces to where this preparation is applied. Then you can rewrite what you want after a short time.
  • · Replies 42 ·
  • · Replies 21 ·
  • · Replies 22 ·
  • · Replies 19 ·
