Critical Angle of Glass Lab: Is My Graph Wrong?
The discussion centers on the critical angle of glass, specifically addressing a student's lab results where the measured critical angle is 38.3 degrees, compared to the established value of 42 degrees for glass in air. The student questions the accuracy of their graph and whether the experimental points align with a straight line. The consensus is that a deviation of 4 degrees from the theoretical value is significant and suggests potential errors in the experimental setup or data collection methods.
  • Understanding of Snell's Law and refractive index calculations
  • Familiarity with graphing techniques and line of best fit
  • Basic knowledge of experimental physics and measurement accuracy
  • Experience with lab equipment used for measuring angles of refraction
  • Review the principles of Snell's Law and its application to critical angles
  • Learn about common sources of error in refractive index experiments
  • Explore techniques for improving data accuracy in experimental physics
  • Investigate the use of software tools for graphing and analyzing experimental data
Students in physics labs, educators teaching optics, and anyone involved in experimental design related to light refraction and critical angles.
lionely
I'm doing a lab, and I plotted a graph for the refractive index I got about 38.3 degrees
and the material I'm working with is a glass block from reading two textbooks I came to the conclusion my graph might be wrong =/, because the critical angle for glass in air is 42 degrees. So is my graph wrong since I'm like 4 degrees off?
Are the experimetal points lying on a straight line?
Yeah I drew a line of best fit.
