# of measurments in order to find parameters
  • Context: Undergrad
  • Thread starter Thread starter ted1986
    Parameters
The minimum number of measurements required to fit a curve to a known function is determined by the function's polynomial degree. For a first-degree polynomial (linear function), two measurements are necessary to solve for two parameters. For a second-degree polynomial (quadratic function), three measurements are needed to solve for three parameters. This principle follows the rule that the number of measurements must equal the number of parameters plus one degree of freedom, expressed as n+1, where n is the polynomial degree.
  • Understanding of polynomial functions and their degrees
  • Basic knowledge of curve fitting techniques
  • Familiarity with systems of equations
  • Experience with mathematical modeling
  • Research "Polynomial Regression" techniques for curve fitting
  • Learn about "Least Squares Method" for parameter estimation
  • Explore "Nonlinear Curve Fitting" methods and tools
  • Study "Statistical Analysis" for evaluating fit quality
Data scientists, statisticians, and researchers involved in data analysis and modeling who need to understand the relationship between measurements and parameters in curve fitting.
ted1986
Hi,
I've got a question about fitting a known function to a measured data.
Suppose I want to find X parameters by fitting a curve to some measurments - What is the minimum number of measurements needed?
Someone has told me that I need X+1 measurments, (because one degree of freedom), but I didn't understand it...
Could someone tell me if its true, and why
Thanks!
Ted
Well, I am no expert on curve-fitting, but let's think about it...
if you knew that your function is a straight line (order 1 "polynomial": ax+b), how many measurements would need to make? Well...you would just need to make 2 measurements so that you could put together 2 equations and 2 unknowns and solve for a and b...that was n+1, where n was the order of the "polynomial" representing your function (1 in this case...this is the highest power for x in the equation).
Now, if you knew that your function was a parabola (ax^2+bx+c)...how many measurements would you need to determine a, b, and c? You would need 3 values for x, plug them in the equation above and form a system of 3 equations and 3 unknowns and solve...that was n+1=3 measurements for a 2nd degree "polynomial"..
...starting to get the picture?
my 2 cents
  • · Replies 0 ·
