I would like to see the math of something
  • Context: Graduate
  • Thread starter Thread starter JT73
The discussion revolves around the concept of a reference frame for photons within the context of special relativity. Participants explore the implications of attempting to define such a frame, the mathematical challenges involved, and the foundational principles of relativity that suggest it is not feasible. The scope includes theoretical reasoning, mathematical formulations, and conceptual clarifications related to the nature of light and reference frames.
  • Some participants question the feasibility of a reference frame for a photon, citing the second postulate of special relativity which states that the speed of light is constant in all inertial frames.
  • Others highlight mathematical issues, such as division by zero when attempting to apply Lorentz transformations to a photon’s frame of reference.
  • One participant suggests that the light cone coordinates can be used to define a frame for a photon, but notes that this does not constitute a Lorentz inertial frame.
  • There are arguments emphasizing the importance of experimental evidence over purely mathematical reasoning, asserting that light's speed remains constant regardless of the observer's frame.
  • Some participants express a desire to see the mathematical derivations that lead to the conclusion that a photon's frame of reference is nonsensical, specifically looking for equations that illustrate these points.
  • Concerns are raised about the reliance on mathematical definitions versus physical reasoning, with some advocating for a balance between the two.
  • Discussion includes the implications of measuring the speed of light and the challenges in defining time intervals in such measurements.
Participants do not reach a consensus on the feasibility of a reference frame for photons. While some agree on the mathematical challenges, others emphasize the importance of experimental validation and express differing views on the interpretation of special relativity principles.
The discussion highlights limitations in understanding the implications of special relativity, particularly regarding the definitions of reference frames and the mathematical transformations involved. There are unresolved questions about the nature of measurements and the assumptions underlying the principles of relativity.
JT73
If someone would be so kind as to show me the math of why a reference frame for a photon wouldn't work?
"Problem #1: In the frame of reference of some photon in that beam, what is the velocity of some other photon in the beam? We have a slight problem here with the second postulate of special relativity, which says that the local speed of light is the exact same value, c, in all reference frames.
Problem #2: Another aspect of special relativity is that one can transform from anyone inertial frame to another using the Poincare transform. Try going to/from the photon frame of reference using this transformation. There will be a slight problem with dividing by zero / multiplying by infinity here."
This was quoted from the user D H in a thread I came across. I would like to see the math involed with is, along with any other equations that back up why photons have a frame of reference wouldn't make sense.
Thank you
You may have better luck posting this in the/a physics forum.
I'm moving this thread to the "Special and General Relativity" forum.
"Math?" Why does there have to be math for everything?
The speed of light is c in all inertial reference frames, by postulate. An inertial frame in which a photon is at rest violates this postulate. Done.
Yes, I know that ZikZak, you're on a science forum, of course we are going to want see math done to back up reasoning...
Now again, I ask if someone would do me the favor of showing me the formula or equations in which 'C' is entered and then the equation comes out with a divison by zero or an answer of infinity or something of the like.
I wish to see this just to better my understanding of the math behind the reasoning. After all math is "the language of physics."
Reasoning is reasoning and math is math. Math is important in physics, but if you become so dependent on the math that you won't accept physical reasoning, then I think you've gone too far.
But ok, the Lorentz boost in the x-direction is defined by:
[tex]t'=\gamma (t-\frac{vx}{c^2})[/tex]
[tex]x'=\gamma (x-vt)[/tex]
[tex]y'=y[/tex]
[tex]z'=z[/tex]
We have defined:
[tex]\gamma=\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
If you plug in v=c (boosting to the frame of the photon), you get gamma is a division by 0 which is a non-nonsensical answer.
You know, you put a lot of trust into equations :)
How about experiments?
We have countless experiments showing us that 'light' doesn't care about what 'speed' you think you are doing, relative some other frame of reference. It always travel at 'c' measured locally. That's the 'frame of reference' for a 'photon'. To deny this you will need to prove it otherwise, not theoretically but by experiment.
You also will need to explain all other experiments telling us that 'c' is a constant.
(Eh, not you matter wave:)
I didn't mean to come off the way I may have. I just always see people talking about light and referencing that a frame of reference for it doesn't work. I understand that reasoning, I do. But for me at least, when I see the math, it becomes even more clear becasue I can picture in my head doing the math instead of picturing in my head a photon traveling at C.
So thank you.
The "frame" of a photon can be defined using "light cone" coordinates.
If you have a Lorentz inertial frame whose coordinates are (t,x,y,z), the light cone coordinates are (a,b,c,d), with
a=(t+x)/√2
b=(t-x)/√2
c=y
d=z.
That is not a Lorentz transformation (you can check by using Matterwave's equations in post #6). Since (a,b,c,d) results from a non-Lorentz transformation applied to the Lorentz inertial coordinates (t,x,y,z), the light cone coordinates do not form a Lorentz inertial frame.
The 'c' that is measured locally is always a round-trip "average speed" for light which has nothing to do with any 'frame of reference', only that the measurement takes place under conditions of the apparatus being inertial, that is, not accelerating. This kind of measurement is covered by Einstein's first postulate, the principle of relativity.
But then Einstein has a second postulate which states that the unmeasurable and unknowable one-way speed of light is also 'c' which is a mathematical statement and the basis for his purely mathematical definition for a Frame of Reference which includes the concept of space-time and four-dimensional events. He also derives the mathematical Lorentz Transform to connect events from one Frame of Reference to another FoR moving at some speed, v, with respect to the first one.
So Einstein's mathematical definition of a FoR and the Lorentz Transform that won't allow for a FoR for anything traveling at v=c with respect to any other FoR which includes photons.
There cannot be any experimental proof for this since the foundation of Einstein's Theory of Special Relativity is purely mathematical. If you want to prove that a photon travels at 'c' or that light propagates at 'c', you're going to need a different theory based on experiments, not mathematics, and I don't think you're going to find one.
Don't get you there ghwellsjr?
Light has only one 'speed' locally, in any experiment, as far as I know. The only way you ever will measure anything is locally. And it doesn't matter how you measure your 'motion' relative some other frame for this.
Are you telling me that this is wrong?
(ignoring it traveling through 'mediums' as glass and water etc for this)
When you make a round-trip measurement of the speed of light, you have one timing device located at the source of the light and a mirror some measured distance away. All you know is total time it takes for the light to get from the source to the mirror and back to the source where the timer is located. You cannot know what time the light hit the mirror and therefore you cannot know in that experiment how fast the light was traveling in each direction. Einstein's solution is to make the two time intervals equal (mathematically). That's his second postulate. Now you can define time on a remote clock with respect to a local clock and from that you can build the mathematical concept of a Frame of Reference.
What if the final answer in the equation in post 6 came out to be an actual number with no divison by zero (meaning the object wasn't moving at C), what does that actually mean? Like if the asnwer comes out to .8, what is that telling you?
The lorentz (boost) transformation must preserve the square-norms of 4-vectors.
So, a timelike-vector (associated with a typical inertial frame) [with square-norm 1] cannot be transformed to a lightlike-vector [with square-norm 0]... and vice versa.
You seem to be overlooking the fact that if there is such a thing as an inertial reference frame of the photon, then that photon would have to have both speed 0 and speed c in it. There is an immediate contradiction even if you don't consider any other photons, so the problem is anything but "slight". (The speed must be 0 because it's assumed to be the reference frame in which the photon is at rest, and the speed must be c because it's assumed to be an inertial frame. The contradiction means that if a photon has a reference frame, it's not an inertial frame). Of course, the same thing can be said about any other photon in the beam.
This is what matterwave was showing you. However, rather than concluding that there's a division by zero problem, you should note that Poincaré transformations don't apply to "the reference frame of the photon", because it can't be defined as an inertial frame. That last part is proved by what I said in the reply to problem #1.
It means that v=0.6c. The other equalities tell you that if I'm moving with speed 0.6c relative to you, I would be assigning coordinates (t',x',y',z') to the event you would be assigning coordinates (t,x,y,z). This is assuming that we both use the inertial coordinate systems that are associated with our motions in a standard way. I would say that the reason why "the rest frame of the photon" doesn't make sense (even if we would allow it to be a non-inertial coordinate system) is that this standard way of associating coordinate systems with non-accelerating objects doesn't work for photons. Some of the details are explained in this post.
You can pick any coordinate system with a time axis that coincides with the photon's world line and call it "the frame of the photon" if you want to. But I don't know a reason why the light cone coordinates should be preferred over any of the others.
Yes. The aim was just to pick a reasonable definition (this one that is actually useful) and show that it is not a Lorentz inertial frame.
Good information in this thread, thanks. Though I would like to point out, Fredrik, that part of my OP was quoted from the user D H in another thread. It isn't my words.
Wait, are you saying in the bolded above that if we were looking for a reference frame of a photon, then we don't neccesarily need to have a speed of 0?
No, the "reference frame of" something is always a frame or a coordinate system such that the "something" has speed 0. What I'm saying is that such a frame must be non-inertial, because in any inertial frame, the speed of light is c≠0
(I also said that there's no non-inertial frame with properties that singles it out as "the" reference frame of the photon).
Sure, but why citing me for that? Use the Michelson–Morley experiment, find a speed. It will be 'c'. That's your experimental definition. Now accelerate a spaceship to some speed relative Earth, then move uniformly. Do the same experiment, you will again find 'c'.
That's what I meant saying that 'c' doesn't care about your moving relative some other 'frame of reference'. It will always come out as 'c', and that's also where the Lorentz contraction comes in, to explain the fact that it never varies, all as I see it.
MMX showed that the two-way speed of light was a constant when measured along different directions and at different speeds for the apparatus, as you pointed out. (Although it didn't measure the value 'c', other experiments did that.) It didn't measure the one-way speed of light, nor did it show that it was a constant in all directions. Neither has any other experiment, nor can any experiment do so. But in your post,
you equated the locally measured speed of light with the speed that light travels (or propagates at) and also with a 'frame of reference' for a 'photon'. But we cannot measure how light propagates or the speed of a photon (since it always travels in one direction). My previous post was to make this clear and especially to point out that we cannot do any experiment to show that any light or photons travel at c, even when we have done an experiment to show that the "average" round trip speed of light is c. Also, I want to make clear that Einstein's second postulate was about the unmeasurable one-way speed of light.
So my question for you is what did you mean by this statement?
"To deny this you will need to prove it otherwise, not theoretically but by experiment."​
Sorry,this isn't clicking fully with me yet guys, but why exactly can't the one way speed of light be measured?
Because we do not have anything faster than the speed of light to communicate to us when the light arrived at a distant location. We cannot see the light once it has left us so we cannot track its progress. Only by having the light reflect off of distant objects can we tell that it has arrived at those objects but it will take some time for the image of the reflection to travel back toward us.
And we cannot just move another clock from our present location to a distant location and expect it to have the same time on it as our local clock because we know that if we bring it back it will have less time on it and we really don't know what happened to the time while it is in transit in either direction.
Okay, I see your thinking now. I wrote "We have countless experiments showing us that 'light' doesn't care about what 'speed' you think you are doing, relative some other frame of reference."
Should have put it "relative 'you comparing it to' some other frame of reference."
That's what I meant when I wrote it :)
Ah well..
Ouch :)
Reading the rest you wrote.
As for your statement that they didn't measure a speed? "As a result of Michelson’s efforts in 1879, the speed of light was known to be 186,350 miles per second with a likely error of around 30 miles per second. This measurement, made by timing a flash of light traveling between mirrors in Annapolis, agreed well with less direct measurements based on astronomical observations." The Michelson-Morley Experiment.
Should Michael Fowler be corrected too?
As for you writing "Also, I want to make clear that Einstein's second postulate was about the unmeasurable one-way speed of light." Yeah, it's true that you can't measure 'c' that way. You need a defined distance, a 'timed source' and a 'sink/detector', but that is as with most other things that exist?
You can use mirrors reflecting starlight though, to check if all stars will give you 'c', splitting the light in two parts at the first mirror, defining your 'start' and then catch the reflected part at a other detector. That should give you a possible estimate of it being a constant, no matter what starlight you mirror.
As an idea, if one doubt it to be a 'constant'. Then you should (expect to) get a difference depending on what star you measure that speed from, moving towards you or away from you etc. Or any other experiment using 'controllable' light sources moving relative yourself.
(this is not correct though, just what someone would expect if it wasn't a 'constant c'. Just so you don't think I'm proposing radiation as a 'variable' here :)
But as you said, there's an awful lot of experiments proving it to be a constant 'c'.
The quote from your link is describing earlier work that Michelson did on his own. MMX is the abbreviation for the experiment done in 1887 which only compared the speed of light along two bi-directional paths 90 degrees apart.
Sorry, I don't know what this is about.
Yes, light from any source will be measured at 'c' when you reflect it off a mirror and do the round-trip thing.
But you don't have to reflect light off a mirror to determine that beams of light from two distant stars traveling at different speeds with respect to us are propagating at the same speed (not necessarily 'c'). All you need is two separate, unsynchronized clocks, placed a distance apart, and you verify that it takes the same difference in time for each light beam to traverse the distance. You don't care what the value of the time interval is, only that it is the same for the two light sources. This is a one-way measurement to show that the speed of the light along a given path is a constant and not dependent on the speed of the source of the light. However, if you look at a pair of stars in another direction, you can prove that the light coming from them is traveling at the same speed but you cannot tell if it is the same speed as the first pair.
There are an awful lot of experiments proving that the round-trip speed of light is equal to the constant 'c', there are none proving that the one-way speed of light is equal to the constant 'c'.
I suggest that you look up the article "One-way speed of light" in wikipedia.
Ah :) Thought you were talking about measuring it without timing the source, sorry about that, which made me confounded. And yes, that is correct. That's also how you can define a 'frame of reference' using clocks in my view. You can look at NIST experiments for seeing how gravity will redefine clocks relative the observer.
You know ghwellsjr. Now that I see what it was you meant, I fully agree with your emphasis of the 'two way' definition of locality. In fact, assuming that your source is your detector, and also letting it be your 'clock' measuring the time between your light leaving and returning, it should be the most precise definition of locality I can think of.
For all other measurements relative a clock you will have the 'time dilations' created by gravity to consider, as per NIST experiments.
Although you can measure one way too "The hypothesis that the speed of light is c relative to its source can easily be disproved by the one-way transmission of light from distant supernovae. When a star explodes as a supernova, we see light coming from material with a large range of velocities dv, at least 10,000 km/sec. Because of this range of velocities, the spectral lines of a supernova are very broad due to the Doppler shift. After traveling a distance D in time D/c, the arrival time of the light would be spread out by dt = (dv/c)(D/c).
However, this DOES NOT happen. For the Crab supernova, with D/c = 6000 years, dv = 10,000 km/sec would give a range of arrival times of 200 years. But the Crab was only bright for 1 year. For very distant supernovae with D/c = 5 billion years, modern observations with spectrographs show that the redshifted and blueshifted light arrives at the same time: within 10 days. This limit on the spread is 5 billion times smaller than the prediction of the "bullet" model of light."
(This is me defining it as a constant btw, using this example, a per my first post.)
From Relativity Tutorial.
Assuming that the ultimate/ideal 'clock' should be radiation, then a definition of lights minimal propagation would be one Plank length in one Plank time. And using that as a definition of a smallest 'frame of reference'/ (& distance) creating a 'time dilation' relative the observer, only the 'two way' experiment can come near to a direct measurement, assuming that the 'clock' is embedded in the source/detector.
So yeah, it's an important point.
Just curious, does the co-ordinate system fail if the speed is not 0?
  • · Replies 90 ·
  • · Replies 30 ·
  • · Replies 21 ·
  • · Replies 28 ·
