Determinant as a function of trace
The discussion revolves around the relationship between the determinant and the trace of square matrices, specifically exploring identities for dimensions 2, 3, and a proposed generalization for dimension 4. The focus includes theoretical aspects and mathematical reasoning related to these identities.
  • One participant states that for dimension 2, the determinant can be expressed in terms of the trace as det A = ((Tr A)² - Tr(A²)) / 2.
  • Another participant references a Wikipedia page that purportedly contains a similar identity for dimension 3.
  • A participant proposes a formula for the determinant in dimension 4 as det A = (p₁₄ - 6p₁₂p₂ + 3p₂² + 8p₁p₃ - 6p₄) / 24, where pᵢ = Tr(Aⁱ).
  • One participant confirms the proposed formula for dimension 4 and suggests checking it using knowledge of eigenvalues.
  • Additional information is provided about the relationship between eigenvalues, the determinant, and the trace, noting that the determinant is the product of eigenvalues and the trace is their sum.
Participants generally agree on the identities for dimensions 2 and 3, and there is a proposed formula for dimension 4, but the discussion does not resolve whether this formula is universally accepted or verified.
The discussion does not clarify the assumptions or limitations regarding the generalization to higher dimensions, nor does it address potential dependencies on definitions or mathematical steps that may remain unresolved.
lukluk
for dimension 2, the following relation between determinant and trace of a square matrix A is true:
det A=((Tr A)2-Tr (A2))/2
for dimension 3 a similar identity can be found in http://en.wikipedia.org/wiki/Determinant
Does anyone know the generalization to dimension 4 ?
lukluk
Thanks very much!
so to see if I understand, the n=4 determinant can be written as
det A=(p14-6p12p2+3p22+8p1p3-6p4)/24
where
pi=Tr (Ai)
...right?
Right!
Btw, you can check this yourself if you know a little bit about eigenvalues.
Did you know that each nxn matrix has n eigenvalues?
And that the determinant is the product of the eigenvalues?
And that the trace is the sum of the eigenvalues?
And the the trace of A^k is the sum of each eigenvalue^k?
  • · Replies 20 ·
