New Reply
Help with determining appropriate pipe size
Share Thread Thread Tools
Nov22-11, 10:47 AM   #1
I'm trying to connect water from a city water supply to a residential fire sprinkler system. The pipe needs to be typical black steel, and hydrostatic test results show a static pressure of 48-psi. What size pipe would I need to achieve at least 26-gpm flow? I've calculated friction loss to be about 5.6-psi over a 100-ft length. Thanks in advance.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Nov22-11, 01:25 PM   #2
How have you calculated friction loss without a pipe size?
26 gpm is pretty low, as is 48 psi. You won't need very big piping to accomodate that flow. Any black steel pipe can handle 50 psi with ease.
It's not what you can "acheive", it's the pressure you need at the end, accounting for pressure drop due to pipe friction. Almost literally any pipe size can accomodate a meager 26 gpm.
For instance, if you NEED 30 psi at the sprinklers, then you need a pipe size that will not reduce the head any lower than that.
Speaking of head, is that 5.6 psi (~13 ft static head) drop accounting for the elevation of the sprinkers?
New Reply
Thread Tools
Similar Threads for: Help with determining appropriate pipe size
Thread Forum Replies
Determining Pressure in Pipe System Introductory Physics Homework 10
air flow through increasing pipe size General Engineering 8
Pressure in a pipe of varying size Introductory Physics Homework 1
Determining the distance of a pipe by the length of an echo General Physics 1
Determining length of a pipe Mechanical Engineering 1
