| New Reply |
Thermodynamics: turbine, steady-state, how to find the necessary mass flow? |
Share Thread |
| Nov22-11, 01:38 PM | #1 |
The problem (tried my best to translate it):
A small high speed turbine is operating on compressed air. It deliveres dW/dT=100 W. At the inlet, the pressure is 400 kPa and the temperature 50*C. At the exit, the pressure is 150 kPa and the temperature -30*C. Neglect the velocity and assume an adiabatic process. Find the necessary mass flow of air through the turbine. My attempt at a solution: I have derived the first law for a control volume: dE/dt=(dQ/dt)-(dW/dt)+∑m_i (h_i+0.5v_i^2+gz_i)-∑m_e (h_e+0.5v_e^2+gz_e) Where t is time, and m_i og m_e is rate of change of mass flow at the inlet and exit, respecitively. Assumed steady state: dE/dt=0. Adibatic dQ/dt=0. Also m_e´=m_i´=m´ By neglecting kinetic and potential energy associated with gravity, i end up with: dW/dt=m(h_i-h_e) <=> m=(dW/dt) / (h_i-h_e) So far so good, but now I need to find the change of enthalphy. We were supposed to solve this task without the use of steam tables. I have tried to use the definition of constant volume heat capacity, but no luck so far. Any input? Thanks in advance. :) e: sorry, this was supposed to go in the homework section. Could a mod please move it? Thanks. :) |
| New Reply |
Similar discussions for: Thermodynamics: turbine, steady-state, how to find the necessary mass flow?
| how to find the steady state solution | Differential Equations | 6 | ||
| Find the steady-state oscillation of the mass–spring system modeled by the given ODE. | Calculus & Beyond Homework | 5 | ||
| Steady state heat flow | Precalculus Mathematics Homework | 1 | ||
| adiabatic steady state flow in a nozzle | Aerospace Engineering | 3 | ||
