Solving ODEs in Matlab without ODE45 or Built-In Functions
  • Context: MATLAB
  • Thread starter Thread starter arizonian
    Matlab
The discussion revolves around solving ordinary differential equations (ODEs) in Matlab without using built-in functions like ODE45. Participants are sharing code snippets and troubleshooting issues related to their implementations, focusing on the Euler method and the structure of their functions.
  • Homework-related
  • Bill describes an issue with his Matlab code where he receives an error about 'too many outputs' when calling the function bloodtest, which is intended to return two derivatives.
  • One participant suggests changing the semicolon to a comma in the bloodtest function to resolve the output error.
  • Another participant points out a potential issue in the initialization of the rhs matrix, indicating a mismatch between the dimensions of the matrix and the expected output from the bloodtest function.
  • Bill presents a new problem related to the indices not working as expected in his updated code for another set of equations, expressing uncertainty about the correctness of the results obtained.
  • Bill reflects on his understanding of differential equations, admitting confusion about the results, despite the code running without errors.
Participants have not reached a consensus on the correctness of the outputs from the ODE implementations, and there are multiple viewpoints regarding the structure of the functions and the handling of outputs.
There are unresolved issues regarding the assumptions made in the function definitions and the expected outputs, as well as the handling of matrix dimensions in the code.
arizonian
I am having trouble with some Matlab code that I am writing. I am attempting to solve ODE writing my own code, per the Professor. That means I cannot use ODE45 or other built-in functions.
My problem: Oiler, a play on Euler, calls another function, FX, that contains the two equations that I am attempting to solve. Oiler is called from the command line by the operator (me).
Command line:
[X,Y] = oiler('bloodtest',2,3,3,4)
Function # 1:
function [rhs] = oiler(FX,a,b,n,h)
r=[a;b]
s=ones(1,n)
t=ones(1,n)
rhs=[s;t]
rhs(:,1)=feval(FX,r);
for i=2:n;
rhs(:,i)=rhs(:,i-1)+feval(FX,rhs(:,i-1))*h
i=i+1;
end
Function # 2:
function [dx,dy] = bloodtest(x,y)
[dx,dy]=[x.^2;2.*y];
I get error flags saying 'too many outputs' for function #2, but I have not yet found a way to call the second function using a vector as the argument.
Any help will be appreciated
Bill
arizonian said:
Function # 2:
[dx,dy]=[x.^2;2.*y];<----LOOK HERE
Hi Bill, I discovered what is reddened in the quoted text. Change the ";" in the second term by ",". Maybe that is giving you some trouble.
I think the problem is here:
rhs=[s;t]
in the first line you make the variable rhs a matrix with two rows and 3 columns, namely:
[tex]\left(\begin{array}{ccc}<br /> 1&1&1\\<br /> 1&1&1\end{array}<br /> \right)[/tex]
but in the next line you say: assign the result of feval(FX,r) to "all rows of the first column" of rhs. But that is a matrix with two rows and one column, while FX (bloodtest) will return a matrix with one row and two columns.
I think you should change FX (bloodtest) to:
Function # 2:
function [dx; dy] = bloodtest(x,y)
[dx; dy]=[x.^2;2.*y];
Got past the first problem, but I am stuck on another problem. The indices don't seem to be working like I think they should.
The equations of interest from the homework assigned:
dy/dx = -2y+5*exp(-x) % (y1)
dz/dx = (-y*z^2)/2 % (y2)
I am incrementing by 0.2. They are coupled, so vector algebra comes into play. Now, on to the code that I am writing.
Command line:
EDU>> e=oiler('P25_11',0,2,4,5,.2)
Function # 1 %%%%%%%%%%%%%%%%%%%%%%%%%
function [rhs] = oiler(FX,xo,y1,y2,n,h)
rhs=ones(2,n);
rhs(:,1)=[y1;y2];
x=xo+h;
% rhs(:,1)=feval(FX,x,rhs(1,1),r(2,1));
% rhs(:,1)=feval(FX,xo,yo,zo);
for k=2:n;
rhs(:,k)=rhs(:,k-1)+(feval(FX,x,rhs(1,k-1),rhs(2,k-1)))*h;
x=x+h;
end
Function # 2 %%%%%%%%%%%%%%%%%%%%%%%
function[dy1y2]=P25_11(x,y1,y2)
dy1y2=[-2*y1+5*exp(-x);(-y1*y2^2)/2];
and the response is:
e =
2.0000 2.0187 1.8816 1.6777 1.4560
4.0000 0.8000 0.6708 0.5861 0.5285
Maybe the response is correct for what I am trying to do, but computing by hand, the first term on the bottom line should be -16. That means the entire bottom row is wrong.
Thanks again
Bill
Maybe my understanding of differential equations with boundaries is suspect. The code does run, the incrementation is taking place like it should. I did compute the second term and it is correct. The third term is correct, and the fourth, and the fifth.
I have egg on my face.
Bill
