Does superconductivity really have zero resistance?
The discussion revolves around the concept of superconductivity and its implications for resistance and energy conservation, particularly in the context of large-scale systems like the Large Hadron Collider (LHC). Participants explore whether superconductivity allows for continuous operation without energy input and the potential conflicts this raises with the conservation of energy principle.
  • One participant questions whether a superconducting circuit, such as that in the LHC, can operate continuously without energy input, raising concerns about energy conservation.
  • Another participant challenges the relevance of the initial example to superconductivity, suggesting a lack of understanding of the physics involved.
  • A participant asserts that a superconducting circuit can run continuously without supplying power, but questions whether this ability allows the circuit to perform work, which could violate conservation of energy.
  • It is noted that the force on a charged particle in a magnetic field does not do work, implying that no energy is required for certain operations in superconducting systems.
  • One participant compares superconducting electromagnets to normal bar magnets, stating that the magnetic field itself cannot do work.
  • A participant expresses curiosity about energy conservation in superconductivity, referencing the Unruh effect and questioning the source of excess energy if the magnets do not do work.
Participants express differing views on the implications of superconductivity for energy conservation, with no consensus reached on whether superconducting systems can operate without energy input or how this relates to established physical principles.
Participants reference various concepts such as the Unruh effect and the nature of magnetic fields, but the discussion does not resolve the underlying assumptions or the implications of these concepts for energy conservation in superconductivity.
clearwater304
Take for instance putting the large hadron collider in space at a near absolute zero where you never have to put energy into cool down the system. The LHC takes 10 GJ to run and the total energy of the two beams is 724 MJ. [1] Since the power to run the system never experiances resistance, would you have to pump power into keep the system going. If not, doesn't it defy the conservation of energy?
http://en.wikipedia.org/wiki/Large_Hadron_Collider
What does this have anything to do with superconductivity having zero resistance? Have you even looked up the physics of superconductivity?
Zz.
The example was questioning whether you can have a circuit run continously without supplying power. According to the wiki page, you can. If so, can that circuit do work on a system, and does that not violate the conservation of energy.
http://en.m.wikipedia.org/wiki/Superconductivity
the force on a charged particle in a magnetic field is at a right angle to the motion therofore no work is done and no energy is required
A superconducting electromagnet is pretty much just like a normal bar magnet in the fact that the magnetic field itself cannot do work.
Thanks, those are good explanations for why no energy is not excerted on the magnets. I'm still curious how energy is conserved. The unruh effect states that the particle would gain vacuum energy due to acceleration. If the magnets aren't doing work on the particle, where does the excess energy come from. If it comes from vacuum energy, how does this not break the conservation of energy.
I'm not trying to prove point, I really do want a good explanation. At first I thought the system must exhibit some sort of resistance becuase every site I read says vacuum energy conserves energy.
  • · Replies 26 ·
12K
