Free fall of ball and acceleration
The discussion revolves around a physics problem involving the free fall of a ball thrown vertically from a height with an initial speed. Participants explore the calculations for the speed just before impact and the time taken to reach the ground for both downward and upward throws.
  • Mixed
  • Participants discuss the application of kinematic equations for calculating final velocity and time of flight, questioning the direction of acceleration and the signs used in the equations.
  • Some participants raise concerns about the assumptions made regarding the initial conditions and the effects of throwing the ball upward versus downward.
  • There is exploration of how the additional height gained when throwing the ball upward affects the final speed and time calculations.
Several participants provide feedback on the original poster's calculations, pointing out potential errors and clarifying the implications of direction in the equations. There is an ongoing exploration of how changes in the problem setup affect the results, with no explicit consensus reached on the correctness of the answers.
Participants note the absence of numerical values in the problem, which complicates the calculations. There is also a clarification regarding the wording of the problem that affects the interpretation of parts c and d.
missrikku
I suppose I am having trouble with this problem because there are no numbers given. Here is the problem:
A ball is thrown down vertically with an initial speed of Vo from a height of h.
a) What is its speed just before it strikes the ground?
Speed is just the magnitude of instantaneous velocity, right? So I just used the equations for velocity:
Vf =?
V^2 = Vo^2 + 2a(Y-Yo)
Since I'm dealing with free fall accel, a = -9.8 m/s^2. In addition, Y-Yo = h. So,
V^2 = Vo^2 + 2(-9.8)h --> V^2 = Vo^2 -19.6h
Leaving me with:
V = (Vo^2 -19.6h)^(1/2)
b) How long does the ball take to reach the ground?
I used: Y-Yo = Vot + (1/2)at^2
and using the quadratic equation, I got:
** i used the "+" version bec t cannot be negative
t = [-Vo + (Vo^2 - 19.6)^(1/2)]/-9.8
c) and d) are the same as a) and b) except this time the ball is thrown upward. I also have to figure out if the values for c and d are less than, greater than, or the same as the values in a and b.
<b>c)</b> I used:
Y - Yo = (1/2)(Vo + V)t
h = (1/2)(Vo + V)t
V = (2h/t) - Vo
I think the values will be the same.
d) For this part, I used the V found in c)
V = (X1 - X)/t1 - t --> V = h/t --> t = h/V
this is the time just to fall from the maximum point the ball reaches, so the total time to fall to the ground would be:
2t = 2(h/V)
Because the time is doubled, I think this value will be greater than the value in b)
Were my assumptions correct?
The formulas you are using are correct.
In part (b), you appear to have left out the "h" in 19.6h
In part (c), the answer should be the same as (a). If you throw the ball up at speed v0, when it passes the level from which it was thrown, on its way down, it will now have speed v0 downward (neglecting air resistance) just as in problem c.
"Because the time is doubled, I think this value will be greater than the value in b)"
Yes, of course, the time in part d will be greater. After you have thrown the ball up, it will (as you say) take a specific time to read it's maximum, the same time to reach level "h" again and THEN the same time as in (a) to hit the ground. In fact you can find that time more eaily by using the same formula as before (with y-y0= 0 instead of h) to calculate the time the ball will take to come back to height h, then add the answer from part (b).
(a) Mistake! You have to keep in mind the DIRECTION of the acceleration. Objects acccelerate downwards. You are also throwing the ball... downwards. And the ball is travelling... you guessed it, downwards. Therefore, v, a and h should all have the same sign, giving V^2 + 2 * 9.8 * h.
(b) See above.
(c) Yep. But your derivation is a bit wrong. Look back at the equation you used for (a), and ask yourself - what difference would changing the sign of Vo make?
(d) Uh... I am confused as to your method...
correction to problem = additional question
I was rereading the problem in the book and I seemed to have missed one of the words. For part c and d the question is What would be the answers to a and b if the ball was thrown upward from the same height and with the same initial speed?
With this in mind, I came up with the following answers:
c) V = (Vo^2 - 19.6(u+h))^(1/2)
where h is the original height and y is the the extra distance the ball traveled when thrown up from that initial height, h. With that in mind, I believed that this value would be slightly larger than the original answer for a because of adding u to h.
d) t = [Vo +- (Vo^2 - 19.6(u+h))^(1/2)]/9.8
I also thought that this value would be slightly higher than the original value found in b because of the additional u added to the height, h. How would I know whether to choose + or the - value for computing the time, t?
With this new information, are my answers correct?
  • · Replies 38 ·
  • · Replies 30 ·
  • · Replies 25 ·
