Vector Addition Help: Find Resultant of 5 Vectors
The discussion revolves around finding the resultant of five vectors given in specific directional formats. The vectors are described using angles relative to cardinal directions, and the problem involves both graphical and numerical methods for determining the resultant vector.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the method of graphing vectors and calculating their components. Questions arise regarding the accuracy of the calculated resultant and the interpretation of results from a calculator app. There is also a request for clarification on how to derive the x and y components of the vectors.
The conversation is ongoing, with participants exploring different methods of calculation and questioning the results obtained. Some guidance has been offered regarding the calculation of vector components, but no consensus has been reached on the correctness of the original calculations.
Participants are working under the constraints of needing to find the resultant both graphically and numerically, and there are indications of potential confusion regarding the output from a calculator app used for component calculations.
katieb123
Find the resultant for the following directions.
20 degrees east of south for 1/2"
80 degrees South of west for 5"
15 degrees west of north for 1"
35 degrees North of East for 3"
40 degrees South of East for 1"
R2 = a2 + b2
i graphed the measurements with each 5" = 1/2" on graph paper. then i connected the tail of the first vector to the head of the end point and measured the resultant but when i calculated it i got 31.55, to calculate this i found the x,y for each vector. vector 1- 4.69,-1.71. vector 2- - and -8.68, -49.24. vector 3- -9.66, 2.59. vector 4- 24.57, 17.21, vector 5- 8.19, -5.74. i added up the totals for each x and y then used the resultant formula to get the resultant to be 31.55. is that correct?
Show your calculations!
i showed calculations can you help?
31.55 was a value you measured on the graph paper, or was it a numerical calculation? Perhaps I'm not clear on what the point of the exercise is. Is the idea to find the resultant by graphical method or by numerical calculation? Or both?
Can you pick a vector, say vector 1, and show how you found the x and y components?
31.55 was found by calculations. i was asked to find both ways graphically and by calculator.
i found the vectors x, y by plugging it in my calculator in an app
Okay. I think your calculator app is giving you the x & y components in reverse order (or you're swapping them somehow), and they seem to be multiplied by 10.
If we take a Cartesian coordinate system where y is North and x is East, then for the first vector the angle is 20° East of South, which is -90° + 20° = -70°. The components are
x = (1/2)*cos(-70°) ; y = (1/2)*sin(-70°)
x = 0.1710 ; y = -0.4698
You should verify that your app gives you these results for the components of vector 1. After that, construct a table with the magnitude, angle, and components for each vector.
  • · Replies 16 ·
  • · Replies 19 ·
