Calculate Interferometer Fringe-Shifts for 10.0cm Chamber with 600-nm Light
  • Thread starter Thread starter cuti_pie75
The discussion focuses on calculating the fringe shifts in a Michelson Interferometer with a 10.0 cm chamber illuminated by 600-nm light. The refractive index of air is given as 1.00029. The calculation involves determining the number of wavelengths traversed in the chamber and adjusting for the change when the air is evacuated, leading to a total fringe shift of 333,430 pairs. The correct approach is to calculate the wavelengths in the chamber with air and then subtract the wavelengths when evacuated.
  • Understanding of Michelson Interferometer design and operation
  • Knowledge of wave optics and fringe patterns
  • Familiarity with refractive index concepts
  • Basic mathematical skills for wavelength calculations
  • Study the principles of fringe shift calculations in interferometry
  • Learn about the effects of refractive index on light propagation
  • Explore advanced topics in wave optics, such as coherence and interference
  • Investigate practical applications of Michelson Interferometers in scientific research
Physics students, optical engineers, and researchers interested in interferometry and wave optics will benefit from this discussion.
cuti_pie75
Suppose we place a chamber 10.0cm long with flat parallel windows in one arm of a Michelson Interferometer that is being illuminated by 600-nm light. If the refractive index of air is 1.00029 and all the air is pumped out of the cell, how many fringe-pairs will shift by in the process?
for this problem, i can't visualize the design of the interferometer at all. All I'm thinking is that m=finge-pairs?, so m=2xn/λo = 333430?
Any help would be good...at least let me know if I'm going to the right direction or not.
Your in the right direction, you calculated the number of wavelengths found when traversing the length of the chamber, twice. Now just subtract the number of wavelengths you would encounter by evacuating the chamber. (Index = 1) This will give you the change in wavelengths which happens to be the number of fringe changes. Hope this helps.
thanx a lot jisland85...i understand now. :)
  • · Replies 24 ·
11K
