Magnetic Field in an Infinitely Long Copper Rod
The discussion focuses on calculating the magnetic field strength in an infinitely long copper rod with a diameter of 10.0 cm carrying a current of 5.0 A. The magnetic field is determined using the formula B = μ/2∏ * I/r, where I is the current and r is the distance from the center of the rod. Participants emphasize the necessity of understanding calculus to solve the problem effectively, particularly in applying Ampere's Law and the concept of current distribution across the rod's cross-section.
  • Understanding of Ampere's Law
  • Basic knowledge of magnetic fields
  • Familiarity with calculus concepts
  • Ability to apply formulas involving current distribution
  • Study Ampere's Law in detail
  • Learn about magnetic field calculations in cylindrical conductors
  • Master calculus fundamentals, focusing on integration
  • Explore current distribution in conductive materials
Students in physics, electrical engineering majors, and anyone interested in understanding magnetic fields in conductive materials.
Xnipes
A long, solid, copper rod has a circular cross-section of diameter 10.0 cm. The rod has a current of 5.0 A, uniformly distributed across its cross-section. Calculate the magnetic field strength at:
a) the centre of the rod
b) 2.5 cm from the centre
c) 5.0 cm from the centre
d) 7.5 cm from the centre
This is supposed to be done somehow using B = μ/2∏ * I/r
I don't have any calculus knowledge.
I've tried many ways, but nothing has been consistent. I assume that I need to figure out the value of I at each different point of the copper rod, which I've tried doing through all this finicky work with area and all this stuff, but I truly don't understand what I'm doing.
Hey,
You stated that,
That's going to be very problematic, and a damper on your solving equations here;
You'll have to consider http://en.wikipedia.org/wiki/Ampere%27s_Law#Integral_form.
Also, remember that you're told that the current is distributed evenly across the cross section, or surface area, in other words, I' = (I/A)*A'(r), where A' is the local area, or, to be precise,
(I/R^2)*r^2, r<=R, where r is the distance from the center, and R=D/2;
So you ought to get, B*2*Pi*r=mu_0*(I/R^2)*r^2.
Master calculus, it's imperative,
Good luck,
Daniel
  • · Replies 25 ·
