Electromagnetic Four-Vector for Uniformly Moving Charge
The discussion centers around the electromagnetic four-vector produced by a uniformly moving charge, specifically contrasting it with the more complex Lienard-Wiechert formula. Participants explore various derivations and references that clarify the relationship between the electric potential of a moving charge and its current position.
  • One participant states that for a uniformly moving charge, the electric potential simplifies to Q/R, where R is the current position, not the retarded position.
  • Another participant suggests Jackson's "Classical Electrodynamics" as a reference, noting that it relates the Lienard-Wiechert potentials to the Lorentz-boosted Coulomb field.
  • A different participant agrees with a previous derivation and mentions multiple methods to arrive at the result, including a brute force substitution into the Lienard-Wiechert formula.
  • One participant critiques Jackson's treatment and recommends Griffiths' work, although they find it less clear than desired.
  • Another book, "Classical Charged Particles" by F. Rohrlich, is mentioned for its comprehensive overview of classical electrodynamics and treatment of radiation reaction.
  • Franklin's "Classical Electromagnetism" is noted for deriving the electric field for constant velocity and showing its equivalence to the Lienard-Wiechert field.
Participants express differing opinions on the clarity and effectiveness of various references for understanding the electromagnetic four-vector for uniformly moving charges. No consensus is reached on a single "convincing" source.
Some participants note limitations in the clarity of existing references and the complexity of deriving results from the Lienard-Wiechert formula, indicating that multiple methods exist but may not be equally accessible.
ApplePion
The general formula for the electromagnetic four-vector produced by a moving charge is the Lienard Wiechert formula, which involves the retarded position of the charge. However, in the special case where the motion of the charge is a uniform velocity motion, the result becomes extremely simple, with the retarded position no longer appearing. For example, the electric potential for a uniform velocity charge located at the origin becomes simply Q/R where R is NOT the retarded position, but actually the current position.
I need to convince someone of this, and it is unlikely he can be convinced by me calculating it for him. Can anyone supply me with a specific reference from a "respected" source where the result is clear. The actual physics calculation need not be clear--I am not really trying to reason with the person as much as to show him that some respected source agrees with me.
Thanks.
Try Jackson, Classical Electrodynamics. Of course, the solution with the Lienard-Wiechert potentials (retarded propagator) is the same as Lorentz boosting the Coulomb field of a point charge at rest to the frame where it is moving with constant velocity.
Thanks Vanhees.
Your derivation is absolutely correct. There are actually two (or more) ways to derive it, with your way being the best because it is simple and intuitive. There is also a brute force way by just substituting into the Lienard Wiechert formula.
As far as I can tell, Jackson actually does not do it. Griffiths does it using the brute force method, and is not as clear as I would like it to have been.
So I am still looking for a "convincing" source.
Another very nice book is
F. Rohrlich, Classical Charged Particles, World Scientific
It gives a comprehensive overview of "microscopic" classical electrodynamics, including a convincing treatment of the self-consistency problem ("radiation reaction") for accelerated charges, interacting with their own electromagnetic field.
Franklin's 'Classical Electromagnetism' derives the E field for constant velocity in Sec. 15.3, and shows that this result is equivalent to the L-W field in Sec. 15.4.3.
  • · Replies 44 ·
