| New Reply |
vertically oscillating rod |
Share Thread | Thread Tools |
| Nov27-11, 06:29 AM | #1 |
Assume all oscillators are frictionless. e) A uniform thin rod (Mass M, length Lo) oscillates vertically on a frictionless axis perpendicular to the rod and passing through one end with period To. Now, a second uniform rod is made of the same material and mounted the same way, so it oscillates vertically about an axis through one end with period T. The length of the second pendulum is L = 9.47Lo. You may assume the rod is essentially one-dimensional. Find the ratio T/To. 2. Relevant equations I = 1/3 ML2, T = 2∏√(I/Mgd) 3. The attempt at a solution T/To = [2∏√(1/3 M(9.47Lo)2/Mgd)] / [2∏√(1/3 MLo2/Mgd)] T/To = [√(1/3 M(9.47Lo)2/Mgd)] / [√(1/3 MLo2/Mgd)] T2/To2 = [(1/3(9.47Lo)2/gd)] / [(1/3Lo2/gd)] T2/To2 = (3gd(9.47Lo)2)/(3gd(Lo)2) T2/To2 = (9.47Lo)2/(Lo)2 T/To = (9.47Lo)/(Lo) T/To = 9.47 The ratio I calculated is wrong. I believe my calculation is in order. Any help in pointing out any possible mistakes is appreciated! |
| Nov27-11, 07:15 AM | #3 |
Thank you for your response Doc Al. I'm thinking d in terms of L would be L/2. Also T = 2∏√(2L/3g). Is this correct?
| Nov27-11, 07:34 AM | #5 |
T/To = 2∏√(2*9.47Lo/3g) / 2∏√(2Lo/3g)
T2/To2 = (2*9.47Lo/3g) / (2Lo/3g) T2/To2 = (2*3g*9.47Lo) / (2*3g*Lo) T2/To2 = 9.47 T/To = 3.077336511 I redid the problem with the substitution of the terms, Is it right that I ended up canceling out most of the terms? |
| Nov27-11, 07:45 AM | #6 |
Mentor
| Nov27-11, 07:55 AM | #7 |
Thank you for your help, I don't think I would've ever thought to make those substitutions on my own.
| New Reply |
| Tags |
| moment of inertia, oscillation period |
| Thread Tools | |
Similar Threads for: vertically oscillating rod
| Vertically oscillating spring-mass system | Introductory Physics Homework | 7 | ||
| Vertically Thrown Rock | Introductory Physics Homework | 2 | ||
| CSS Float Vertically? | Brain Teasers | 0 | ||
| Pulling a box vertically | Introductory Physics Homework | 2 | ||
| object thrown vertically | Introductory Physics Homework | 5 | ||
