How Do I Find a Wave Function for a Neutron in a Double Slit Experiment?
The discussion focuses on deriving the wave function for a neutron in a double slit experiment, specifically with parameters such as slit spacing (d = 1.00 x 10^-3 m), distance to detector (L = 10.0 m), neutron velocity (v = 0.400 m/s), and mass (w = 1.67 x 10^-27 kg). The user proposes a cosine function for the wave function, suggesting it could represent the interference pattern, but seeks validation and justification for this choice. The conversation emphasizes the complexity of finding a wave function and the necessity of considering boundary conditions and neutron properties to arrive at a definitive solution.
  • Understanding of quantum mechanics principles, particularly wave-particle duality.
  • Familiarity with the double slit experiment and its implications in physics.
  • Knowledge of wave functions and their mathematical representations.
  • Basic grasp of trigonometric functions and their applications in physics.
  • Study the derivation of wave functions in quantum mechanics, focusing on neutron behavior.
  • Explore boundary conditions relevant to wave functions in quantum systems.
  • Review examples of wave functions from similar quantum mechanics problems.
  • Consult advanced physics textbooks or academic papers on wave-particle duality and interference patterns.
Students of quantum mechanics, physicists working on wave functions, and anyone interested in the mathematical modeling of quantum phenomena, particularly in experimental setups like the double slit experiment.
bannadonna
On My Last Straw Trying to Find a Wave Function
I am horribly confused as how to I can actually find a wave function for any given problem. The specific wave function I am trying to find right now is that of a neutron passing through a double slit apparatus. Here is how I have the problem set up thus far:
d= spacing between slits= 1.00 x 10^-3 m (or 1.oo mm)
L= distance between slit apparatus and the detector array = 10.0 m
y= distance on detector array from major maximum (the one in the middle)
m= # of high intensity bands away from middle with the middle one at m=0
v= velocity of the neutron = .400 m/s
w= mass of neutron= 1.67 x 10^-27 kg
h=Planck's constant = 6.63 x 10^-34 Js
I know that the wave function should demonstrate where the destructive interference is going on by being zero when y=(m+.5)(hL/vwd). It should also show the bright spots as maximums and minimums at y=(mhL)/(vwd). I figured that since wave functions are a lot like amplitude functions, this will be a cosine function. My best guess is ... what's that pitchfork sign? ... anyway, that the wave function equals cos(2(pi)ywv/h). Sorry, I don't know how to put a pi in the equation. :rolleyes:
This cosine function maxes at y=0, which is good; that is what the interference pattern does. But a lot of trig functions could do that, and I cannot justify why mine is a good one. Is it a wave function that describes this neutron? If it is, why? If not, how do I find a function that does?
I can understand your frustration and confusion in trying to find a wave function for a specific problem. It can be a complex and daunting task, especially when dealing with a problem like a neutron passing through a double slit apparatus. However, it is important to remember that finding a wave function is not an exact science and there may be multiple possible solutions.
Based on the information provided, it seems like you have a good understanding of the variables involved and the general form of the wave function. However, as you mentioned, there could be many different trigonometric functions that could fit the criteria you have set. In order to determine the correct wave function, you may need to consider additional factors such as the boundary conditions and the specific properties of the neutron.
One approach you could take is to look at similar problems and their corresponding wave functions. This could give you some insights and help you to narrow down the possibilities. You could also consult with a physics professor or seek out additional resources for guidance.
Remember that finding a wave function is not a simple task, but with patience and persistence, you will eventually find a solution that fits the problem. Keep exploring and don't give up on your search.
  • · Replies 105 ·
9K
  • · Replies 36 ·
10K
11K
