Deriving an Expression for a Sinusoidal Wave on a String
  • Thread starter Thread starter krazeekid7
    Wavefunction Waves
The discussion focuses on deriving the expression for a sinusoidal wave traveling on a string in the negative x-direction. The wave has an amplitude of 1.00 cm, a frequency of 200 Hz, and a wavelength of 3.00 cm. The derived equation is y(x,t) = 1.00 cm * sin((2π/3.00 cm)x - (2π * 200 Hz)t + π/2), where the phase constant φ is determined to be π/2 based on the initial conditions provided. This expression accurately describes the wave's behavior at t=0, where the particle at x=0 is displaced 0.80 cm from equilibrium and moving upwards.
  • Understanding of sinusoidal wave equations
  • Knowledge of wave parameters: amplitude, frequency, wavelength
  • Familiarity with phase constants in wave motion
  • Basic trigonometry and calculus concepts
  • Explore the derivation of wave equations in different media
  • Learn about wave interference and superposition principles
  • Investigate the effects of damping on wave motion
  • Study the applications of sinusoidal waves in real-world scenarios
Students and educators in physics, particularly those studying wave mechanics, as well as engineers and professionals involved in acoustics and vibration analysis.
krazeekid7
How would I get an expression y(x,t) that describes a sinusiodal wave traveling on a string in the negative x-direction with amplitude in the y-direction of 1.00cm, frequency 200Hz, and wavelength 3.00cm? At t=0, the particle of string at x=0 is displaced D=0.80cm from equilibrium and moving upwards.
Can you figure out what [itex]\phi[/itex] has to be?
[tex]y(x, t) = 1.00 \times \sin \left( 2 \pi \frac {x}{3.00} + 200 \times 2 \pi t + \phi\right)[/tex]
To get an expression for this scenario, we first need to understand the basic equation for a sinusoidal wave:
y(x,t) = A*sin(kx - ωt + φ)
where A is the amplitude, k is the wave number (2π/λ), ω is the angular frequency (2πf), and φ is the phase constant.
In this case, we are given A = 1.00cm, f = 200Hz, and λ = 3.00cm. Plugging these values into the equation, we get:
y(x,t) = 1.00cm*sin((2π/3.00cm)x - (2π*200Hz)t + φ)
Now, we need to determine the value of φ. We are given that at t=0, the particle at x=0 is displaced D=0.80cm from equilibrium and moving upwards. This means that the initial phase of the wave is such that the particle is at its maximum displacement (D = A = 1.00cm) and moving upwards (positive direction). This corresponds to a phase angle of π/2.
Substituting this value into the equation, we get our final expression for the wave:
y(x,t) = 1.00cm*sin((2π/3.00cm)x - (2π*200Hz)t + π/2)
This equation describes a sinusoidal wave traveling in the negative x-direction with an amplitude of 1.00cm and a frequency of 200Hz, with a wavelength of 3.00cm. At t=0, the particle at x=0 is at a displacement of 0.80cm from equilibrium and moving upwards.
