How to Create a Hand Crank for 24000rpm DC Motor
  • Thread starter Thread starter jhendren
    Crank hand
Creating a hand crank to achieve 24000 RPM with an 18V DC motor from RadioShack is theoretically possible but impractical. A hand crank operating at 60 RPM would require a 1:400 gearbox to reach the desired speed, significantly reducing output torque by a factor of 400. Most hand-crank generators utilize motors that operate at a maximum of a few thousand RPM, typically employing gearboxes around 1:20. Therefore, the design is not feasible for practical applications.
  • Understanding of DC motor specifications, particularly 18V motors.
  • Knowledge of gearbox mechanics and ratios.
  • Familiarity with hand-crank generator designs.
  • Basic principles of torque and rotational speed.
  • Research gearbox design and selection for high-speed applications.
  • Explore alternative motor options that operate at higher RPMs.
  • Investigate hand-crank generator efficiency and torque requirements.
  • Learn about the mechanical limits of hand-crank systems in generating electricity.
Engineers, hobbyists, and inventors interested in mechanical design, particularly those exploring hand-crank generators and high-speed DC motor applications.
jhendren
I want to create a handcrank to spin a DC motor at 24000 rpm. The DC motor is an 18V hobby motor from radioshack. Is this possible?
Possible yes, practical no.
You'll never be able to crank it fast enough with practically sized gearing.
If you figured you would be able to spin a hand crank at about 60rpm (1 rev/sec), that means you'll need a 1:400 gearbox to step up the speed (and it will reduce your output torque by a factor of 400 as well). My guess is most hand-crank generators utilize a motor which spins at a couple of thousand rpm at most, meaning the gearbox is on the order of 1:20 or so.
  • · Replies 17 ·
  • · Replies 55 ·
13K
  • · Replies 19 ·
