Proving |f(z)|≤ M in a Closed Contour C
  • Thread starter Thread starter Anowar
    Closed
The problem involves proving that if a function f(z) is analytic within a closed contour C and continuous on C, with the condition that f(z) ≠ 0 within C and |f(z)| ≤ M on C, then |f(z)| ≤ M for all points within C. The discussion centers around the implications of the maximum modulus principle and the conditions under which the theorem holds.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the use of Gauss' mean value theorem and Cauchy's integral theorem to argue about local maxima of |f(z)|. There is a suggestion to consider the function w(z) = 1/f(z) and its implications for continuity and analyticity. Some participants question the necessity of the condition f(z) ≠ 0 and discuss the maximum modulus principle in relation to the problem.
The discussion is ongoing, with various interpretations being explored. Some participants express confusion regarding the relationship between the two problems presented in the text, particularly how the conditions of f(z) being zero affect the conclusions drawn from the maximum modulus principle. Guidance has been offered regarding the implications of the maximum modulus principle, but no consensus has been reached.
Participants note the potential contradictions in the text regarding the behavior of f(z) when it is zero within the contour C, raising questions about the validity of the original problem's assumptions and the implications for the proof.
Anowar
This problem is from Mathematical methods for physicists by Arfken, problem 6.4.7.
A function f(z) is analytic within a closed contour C (and continuous on C). If f(z) ≠ 0 within C and |f(z)|≤ M on C, show that |f(z)|≤ M for all points within C.
The hint is to consider w(z) = 1/f(z).
I have tried to solve this in this way using Gauss' mean value theorem. Suppose, there is a point within C where |f(z)|≥ M. As |f(z)|≤ M on C, there has to be a local maximum of |f(z)| within C. We call that point of local maximum z°. Then we can take a circle with a however small radius r around z°. From Cauchy's integral theorem,
f(z°) = (1/2πi)∫c[f(z)/(z-z°)] dz (here c is the small circle of radius r)
Now taking, z = z° + r*exp(iθ)
f(z°) = (1/2π)∫ f(z° + r*exp(iθ)) dθ
Taking the modulus, |f(z°)| = 1/2π |∫ f(z° + r*exp(iθ)) dθ| ≤ 1/2π ∫ |f(z° + r*exp(iθ))| dθ
(in all cases above, the integral is taken from 0 to 2π).
Now, m(f) = 1/2π ∫ |f(z° + r*exp(iθ))| dθ is the mean value of |f(z)| on the circle of radius r. From above, we rewrite,
|f(z°)| ≤ m(f).
Again, there must be at least one point z1 on the circle where |f(z1)| is larger than m(f) or the |f(z)| is equal to m(f) for all the points on the circle. So, |f(z1)| ≥ m(f) ≥ |f(z°)|. We can take r as small as we want to make z1 as nearer to z°. So, there is point z1 in the neighborhood of z° for which, |f(z1)| ≥ |f(z°)|, so |f(z°)| can't be a local maximum, and thus there is no point inside C such that |f(z)| ≥ M.
Now, my problem is that, I didn't use the condition f(z) ≠ 0 within C for this proof. So, there should be a problem with my solution, but I couldn't find any. Now, thinking about the hint, taking w(z) = 1/f(z), we don't know whether w(z) is continuous on C or not. For, f(z) = 0 for some point on the contour C, w(z) is not continuous and we can't take Cauchy integral of w(z) on C to be zero. But, for f(z), as it is continuous on C and analytic inside, it's contour integral on C would be zero from Cauchy-Goursat theorem. I think I could use this to solve the problem, but I failed to find any path to do so. I would appreciate it very much if someone can point out where I am doing wrong or give some more hints to solve this. I am sorry for the bad format of equations as I am not yet used to using latex.
Its late so maybe I am missing something but you don't need f≠0. This follows from the maximum modulus principle that a holomorphic function on a compact subset of ℂ attains its maximum value on the boundary.
But, in the text, the right next problem is,
If f(z) = 0 within the contour C, show that the foregoing result (the statement of the previous problem) does not hold and that it is possible to have |f(z)| = 0 at one or more points in the interior with |f(z)| > 0 over the entire bounding contour.
As it says, it does not hold if f(z) = 0 then there have to be some problem with the text then. Any clue?
I don't see how that contradicts your first statement:
I think what the question is trying to get at is the "minimum modulus principle." That is if f is never zero then |f| attains its minimum on the boundary as well.
The first problem asks to show that |f(z)|≤ M if f(z)≠0 within C and the second one asks to show that, |f(z)|≤ M does not hold if f(z)= 0 within C.
If the f(z) has its minimum on the boundary, how can it help me to show that |f(z)| is bounded within the region? Thanks for you help, I really appreciate your kind replies.
I think the question is written wrong. If |f| > 0 on the boundary but f = 0 at some point inside this doesn't contradict the fact f has its "maximum modulus" on the boundary.
I think the question doesn't want to arrive at maximum modulus principle, it is asking to proof that a function is bounded within the region if its bounded on the boundary. Am I missing something here?
  • · Replies 16 ·
