What is the final velocity of the ball?
  • Thread starter Thread starter rzlblrt417
    Ball Collision
The discussion revolves around a physics problem involving a ball colliding with a wall at an angle of 60 degrees. The participants are examining the momentum of the ball before and after the collision, as well as the forces involved during the impact.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to calculate the momentum of the ball before and after it strikes the wall, questioning how time factors into the calculations. There are discussions about the correct application of momentum equations and the geometry involved in the problem.
There is an ongoing exploration of the relationship between the momentum before and after the collision, with some participants providing hints and corrections regarding the calculations. The discussion is dynamic, with multiple interpretations being considered, particularly around the geometry of the situation and the role of time in the calculations.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is also a focus on ensuring that the calculations align with the physics principles being discussed.
rzlblrt417
a ball hits a wall at 60 degrees from the wall and leaves the wall at 60 degrees.
v1 = 10 m/s
v2 = 10 m/s
m = 3.00 kg
t = 0.200s
p = mvcos(angle)
J = p2 - p1
p = (3.00)(10)(cos(60))
p1 = 15
p2 = 15
and that is as far as i can get. I am not sure how time plays into this. Any help is appreciated. I have the text in a few hours. Thank you
what is being asked for?
v1 = 10 m/s
v2 = 10 m/s
m = 3.00 kg
t = 0.200s
p = mvcos(angle)
J = p2 - p1
p1 = 15
p2 = 15
As grzz said , I cannot understand what you are trying to find out. Anyways what's the question asking for ?
My apologies, I always do that. Force on by the wall on ball
*by wall on the ball
Got that ! Ok so what is p1 ? Or I mean momentum of the ball before striking the wall ?
Then you find out p2 or the momentum of ball after it stroke the wall.
What do you get ?
What do you get ?
the same thing for p1 as p2?
14.7n?
No p1 and p2 aren't same. Be careful regarding geometry.
Hint : see the image : http://postimage.org/image/qvnhzhnsl/
Above answer is wrong.
Look at image
ok so then
p1 = (3.00)(10)cos(30)
p2 = (3.00)(10)cos(60)
so p2 - p1 = -14.133 so then it would just be 14.133N?
or is it sin(30) making it 14.5N
rzlblrt417 said:
ok so then
Correct.
Right !
Nope. What about time t ?
From Newton's second law : F= Δp/Δt = p1-p2/t
Plug in it. What do you get ?
Do calculations properly. You got it wrong for p1-p2 also.
sankalpmittal said:
Correct.
Right !
OH! ok so then after plugging everything in i got 71.6N!
Your method of evaluation is correct but calculations are wrong. Do you know the value of cos 60o and cos 30o ? What are they ?
  • · Replies 23 ·
  • · Replies 24 ·
