Projectiles: Bullet Fired into Block
The discussion focuses on calculating the initial velocity (Vi) of a bullet fired into a block using principles of physics, specifically conservation of momentum and kinematics. The bullet, weighing 9 g, is fired into a 303 g block, which is initially at rest. After the impact, the block lands 1.5 m from the table's edge, and the calculated initial velocity of the bullet is determined to be 85.96 m/s, although some participants suggest the correct value is 83.2 m/s. The key equations used include ΔX = Vi(t) + (1/2)(a)(t^2) and the momentum conservation equation m(Vf-Vi) = -m(Vf-Vi).
  • Understanding of kinematic equations, specifically ΔX = Vi(t) + (1/2)(a)(t^2)
  • Knowledge of conservation of momentum principles
  • Familiarity with basic physics concepts such as mass, velocity, and acceleration
  • Ability to solve quadratic equations for time and velocity
  • Study the conservation of momentum in elastic and inelastic collisions
  • Learn how to apply kinematic equations in projectile motion scenarios
  • Explore the effects of different masses on collision outcomes
  • Practice solving similar physics problems involving projectile motion and momentum
Students in physics courses, educators teaching mechanics, and anyone interested in understanding the principles of motion and momentum in collision scenarios.
kah22
A(n) 9 g bullet is fired into a 303 g block that is initially at rest at the edge of a frictionless table of height 1.9 m. The bullet remains in the block, and after impact the block lands
1.5 m from the bottom of the table. The acceleration of gravity is 9.8 m/s/s.
Find the initial velocity (Vi) of the bullet in m/s.
I separated the equation into vertical and horizontal parts.
Horizontal: ΔX=1.5, a = 0 m/s/s
Vertical: ΔY= -1.9, a= -9.8 m/s/s, Vi = 0 m/s (because it is launched horizontally).
Using the kinematic equation ΔX = Vi(t) + (1/2)(a)(t^2) to solve for the vertical time:
-1.9 = 0(t) + 1/2 (-9.8)t^2
-1.9 = -4.9t^2
t^2 = 0.38775
t = 0.623 seconds
Since the vertical time is equal to the horizontal time, I plugged this time into the same kinematic equation to solve for the horizontal Vi:
1.5 = Vi (0.623) + 1/2(0)(0.623)
1.5 = Vi (o.623)
Vi = 2.41 m/s
This Vi is equal to the velocity at which the block and bullet are launched from the table.
I know the mass of the bullet, the mass of the block and bullet combined (312 g), the Vf (which is the Vi from the equation above), and the Vi of the block and bullet combined (0, since it is at rest). I can use the collision equation to solve for the Vi of the bullet.
9(2.41-Vi) = -312(2.41-0)
21.69 -9Vi = -751.92
-9Vi=-773.61
Vi=85.96 m/s
The grading system says this answer isn't correct. I checked my math but I think I am missing something. Can anyone tell me what I am doing wrong?
I agree with your t = 0.623s and your Vi = 2.41m/s
I think your mistake is in the last part. In the collision of the bullet with the block momentum is conserved so if you write:
Momentum of bullet = momentum of (block+bullet) see what you get
I got the velocity of the bullet to be 83.2m/s...what is the answer, do you know?
-9Vi=-773.61
Vi=85.96 m/s
According to the red equations m(Vf-Vi) =0, as zero alone is equal to the negative of itself.
Use conservation of momentum in the correct form. You have two objects with different masses and different initial and final velocities. Use proper notations.
ehild
