How to Solve a Damped Harmonic Oscillator Problem?
The discussion revolves around a damped harmonic oscillator problem involving a block, spring, and damping force. The original poster is tasked with finding the damping coefficient and the energy lost after a certain number of oscillations, but expresses uncertainty about how to begin the problem.
  • The original poster attempts to calculate the period of oscillation and relates it to the damping effect on amplitude. They express confusion about how to proceed with the given equations.
  • Another participant suggests using the differential equation for damped oscillation and provides a method to relate the amplitude decrease to the damping coefficient.
  • There are mentions of using logarithmic relationships and energy formulas to find the required values, but no complete methods are outlined.
Participants are exploring various approaches to the problem, with one providing a potential method involving the relationship between amplitude and time. However, there is no explicit consensus on the best way to proceed, and the original poster continues to seek clarification.
The original poster notes that they have limited equations from their textbook and are unsure how to apply them to find the damping coefficient.
wannabeadoc05
Hi,
I'm having a lot of trouble with a damped harmonic oscillator problem:
A damped harmonic oscillator consists of a block (m=2.00kg), a spring (k=10 N/m), and a damping force (F=-bv). Initially it oscillates with an amplitude of 25.0cm. Because of the damping force, the amplitude falls to 3/4 of this initial value at the completion of four osciallations. (a) What is the value of b? (b) How much energy has been "lost" during these four oscillations?
The truth is. I'm not really sure where to start. My book only gives a few equations to work with and I'm not sure how to relate them to find the value of b.
The first thing I did was find the period (T), by the equation
T=2∏ √(2.0Kg/10N/m) = 2.8s
...,but I'm not really sure what to do with it.
Any help with this would be awesome!
Thanks
wannabeadoc05 said:
Hi,
Thanks
The equation for the damped oscillator along let's say the "x" axis reads:
[tex]m\frac{d^2 x}{dt^2}+v\frac{dv}{dt}+kx=0.[/tex].
The period is [itex]T=2\pi\sqrt{\frac{m}{k}}[/itex].The amplitude of the oscillations descreases with time exponentially as it would be shown by solving the differential equation above:
[tex]A(t)=A_{0} \exp({-\frac{b}{2m}t})[/tex].
Use tha fac that 4 periods mean a certain amount of time (4T=t) and the fact that [itex]A(4T)=3/4 A[/itex],plug it in the equation,simplify through A,take the logaritm,substitute t=4T and the value of m to find your answer.
Use the total energy formula (kinetic+potential)in which u plug the correct figures u have.The result should be pretty simple.The energy lost is just the difference between the one at the intial time and the one after 4T.BTW,your first calculation for the period of oscillation was correct.
Good luck!
Thanks!
Thanks,
You are awesome!:smile:
wannabeadoc05 said:
Thanks,
Thank You! :blushing:
