New Reply
How stirring a liquid affects temperature measurements.
Share Thread Thread Tools
Nov29-11, 11:48 PM   #1
"Some people say stirring a hot liquid with a thermometer gives a better measurement and some say it yields a worse measurement. Explain with physics how one is actually better"
2. Relevant equations
None that I know of.
3. The attempt at a solution
I know that stirring a liquid generally cools it, but I was also thinking that the increased kinetic energy due to the stirring may cause an increase in temperature. Also, stirring would evenly distribute the liquid so that the average temperature would be more measurable, but if it changes the temperature through the previously stated ways, then wouldn't it be worse?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Nov30-11, 01:53 AM   #2
Quote by dJordiB View Post
Gee, my immediate reaction is that stirring gives you a more accurate measurement, but that's because I've had a couple of heat transfer courses. If you don't stir, the heat transfer is limited by natural convection, that is, a film of cool liquid forms around the end of the thermometer and gives an artificially low reading. Stirring disrupts the film and provides much better "forced convection" heat transfer. It exposes the tip of the thermometer more directly to the bulk fluid. I'm not sure what principles of physics you could quote for that, although I have some textbooks with a number of methods for calculating film coefficients of heat transfer under natural and forced convection....
BBB
Nov30-11, 02:02 AM   #3
That's great thank you so much! I was leaning toward that answer but didn't have much of a justification.
New Reply
Tags
heat, measurement, thermodynamics, thermometer
Thread Tools
Similar Threads for: How stirring a liquid affects temperature measurements.
Thread Forum Replies
Internal energy when stirring a liquid. Introductory Physics Homework 5
How temperature affects the power output from an apple Introductory Physics Homework 0
If temperature is motion, why doesn't stirring water make it boil? General Physics 14
How temperature affects GM tube performance? General Physics 2
How pressure and temperature affects volumetric flow? Classical Physics 6
