Inflation and expansion of spacetime
The discussion centers on how a positive-energy false vacuum generates exponential expansion of spacetime, as described by Einstein's field equations in General Relativity. The relationship between the expansion rate H(t) and energy density ρ(t) is established, leading to the conclusion that the scale factor a(t) grows exponentially due to the constant energy from the false vacuum. The role of pressure in gravity is highlighted, particularly how negative pressure from vacuum energy can lead to antigravity effects, influencing the universe's accelerated expansion phase.
  • Understanding of General Relativity and Einstein's field equations
  • Familiarity with differential equations and their applications
  • Knowledge of cosmological concepts such as vacuum energy and the cosmological constant
  • Basic grasp of the relationship between energy density and expansion rate in cosmology
  • Study the implications of vacuum energy in cosmology
  • Learn about the cosmological constant and its role in the universe's expansion
  • Explore the mathematical foundations of differential equations in physics
  • Investigate the effects of negative pressure in various cosmological models
Astronomers, physicists, and cosmologists interested in the dynamics of the universe's expansion, particularly those studying the implications of vacuum energy and General Relativity.
stglyde
How come a "positive-energy false vacuum would, according to general relativity, generate an exponential expansion of space"?
Space news on Phys.org
If we have a smoothly-distributed energy density, then the expansion of space (neglecting spatial curvature) can be written as:
[tex]H(t)^2 = \rho(t)[/tex]
(neglecting constants for clarity)
This can be derived directly from the Einstein field equations in General Relativity. Here [itex]H(t)[/itex] is the expansion rate, defined as:
[tex]H(t) = {1 \over a(t)}{d \over dt}a(t)[/tex]
...and [itex]\rho(t)[/itex] is the energy density of the universe. Now, if the energy comes just from a false vacuum, then that energy is a constant. So if we define [itex]H_0 = H(t=0)[/itex], then we can simply write:
[tex]{1 \over a}{da \over dt} = H_0[/tex]
So now we have a simple differential equation. I can then multiply both sides by the scale factor [itex]a[/itex] to put the differential equation in a more familiar form:
[tex]{da \over dt} = H_0 a[/tex]
If you know your most basic differential equations, this should look very familiar to you: the rate of change in the scale factor is proportional to the scale factor. This is the equation for exponential growth!
[tex]a(t) = a(t=0) e^{H_0 t}[/tex]
(If you're having difficulty, think compound interest: the amount added to your bank account each month is proportional to your balance, which means that your bank account balance grows exponentially).
And in case that excellent mathematical answer still leaves you some questions about the basic physics at a more descriptive level, I would point out that in general relativity, gravity does not just come from rest mass (and hence rest energy), it also comes from pressure. Usually the pressure contribution is negligible-- like the way the pressure of the Sun contributes to its gravity is totally swamped by the way its rest mass contributes to its gravity. But that's because the Sun is mostly nonrelativistic gas-- vacuum energy would be working in a highly relativistic way, whatever is causing it. Now, in unusual situations (like with vacuum energy), pressure can not only be important to gravity, it can be related to energy in weird ways-- in particular, it can be negative when the energy is positive!
The reason for this is that pressure is basically how much energy you can remove from a system when you expand it a given tiny amount, but to expand vacuum, it requires more vacuum-- which if vacuum holds energy, requires that you add energy! So you don't extract energy when vacuum expands, you need to add it instead. That means the pressure of vacuum is negative if there is vacuum energy, and that means its gravity is negative too (or "antigravity"). So two masses placed far enough apart actually experience a kind of repulsion-- due to the vacuum between them (using the cosmological constant model-- so simple vacuum energy).
Now, normally this requires a whole lot of vacuum to be in there, so perhaps this is why we are just now starting to see this effect in our expanding universe (the accelerated expansion phase that is just getting going). But if there was a very early phase of the universe where there was a huge energy associated with a "false vacuum", then even with dense positive pressure there could be a huge negative pressure component, just for a short while, that could have created the inflation. After the false vacuum "decayed", it no longer had that huge antigravity, and the normal gravity of all the positive pressure and rest mass would have taken over, until the recent era of acceleration.
  • · Replies 37 ·
  • · Replies 33 ·
10K
