Converting 2nd Order ODE to 1st Order ODE
  • Thread starter Thread starter johnwalton84
    2nd order Ode
The discussion revolves around converting a second order ordinary differential equation (ODE) into a system of first order ODEs. The original poster presents a nonlinear system described by the second order ODE and seeks guidance on how to transform it into a pair of first order equations.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to understand how to handle the nonlinear term in the ODE and questions the process of obtaining a pair of first order equations. Some participants suggest substituting the velocity variable and identify the resulting equations, while others mention numerical methods for solving the transformed equations.
Participants are actively engaging with the problem, with some providing hints and suggestions for substitution and numerical methods. There is a recognition of the complexity involved in solving the resulting equations, particularly due to the nonlinear nature of the system.
The original poster expresses uncertainty about the transformation process and the implications of the nonlinear term. There is mention of specific methods, such as the Runge-Kutta method, for evaluating the equations once transformed.
johnwalton84
I'm stuck as to where to start with this question:
The position function x(t) in a certain nonlinear system is described by the second order ODE:
< equation.gif >
Transform this ODE into a pair of first order ODEs for x1=x and x2=dx/dt. (Note that x2 represents the velocity in this system.)
I've thought about calculating the homogeneous equation and then the particular integral, but (a) how is this done with a sin(dx/dt) on the RHS and (b) how does this yield a pair of solutions? Or is there another way to go about it?
Show us what happens when you substitute x2=dx/dt. Isn't that a 1st order equation? What's the other one? Hint: it is given in this very post.
Krab,u should have given him the result and let him strive to find the solution for the messy equation he gets:
[tex]\frac{dx_{1}}{dt}=x_{2}[/tex]
[tex]\frac{dx_{2}}{dt}=-\int x_{2}dt- \alpha\sin x_{2}[/tex].
That should fully answer your problem.If u want to solve the second equation,try numerical methods.It is a nonlinear first order integro-differential equation with constant coefficients.Impossible to solve analytically.For almost all cases.
Thanks, I guess I was expecting the problem to be harder than that :rolleyes: . Yeah, the second part of the question involves evaluation by the Runge-Kutta method. :smile:
These are the first order equations:
[tex]\frac{dx_1}{dt}=x_2[/tex]
[tex]\frac{dx_2}{dt}=-x_1- \alpha\sin x_2[/tex]
In this form, they can be used directly in a canned Runge-Kutta routine.
