Is the Bulk a 12-Dimensional Manifold Housing Parallel Universes?
  • Context: Graduate
  • Thread starter Thread starter Vinni
The bulk is defined as the manifold containing dimensions orthogonal to the brane of interest, with the dimensionality varying based on the cosmological model. In standard braneworld models, our universe is represented as a 3-brane, while parallel universes can be conceptualized as separate branes existing in higher-dimensional space. Gravity may be unique among forces, potentially diffusing into the bulk, which could explain its relative weakness in our observable dimensions. This discussion highlights the relationship between branes and parallel universes, emphasizing the implications for understanding gravity and dimensionality.
  • Understanding of brane cosmology
  • Familiarity with string theory concepts
  • Knowledge of dimensionality in physics
  • Basic grasp of parallel universe theories
  • Research the implications of brane cosmology on gravitational theories
  • Explore the role of extra dimensions in string theory
  • Investigate methods for detecting gravitational effects from parallel universes
  • Learn about the mathematical models of higher-dimensional spaces
Physicists, cosmologists, and anyone interested in advanced theoretical physics, particularly those exploring the concepts of brane cosmology and parallel universes.
Vinni
Is the bulk the manifold container with 12 dimensions? Also are parallel universes those that operate across different dimensions? For instance our universe operates in dimensions 1, 2, 3, but a parallel universe could operate in dimensions 4,5,6?
In standard braneworld models of cosmology, parallel universes can be thought of as separate branes evolving in a higher dimension space. So, for example, in such a set-up our universe would be a 3-brane (3 extended spatial dimensions). We can imagine a 4th spatial dimension orthogonal to the 3 dimensions of our brane. We could then in principle fill the 4th dimension with many other 3-branes (think of stacking cd's on a spool -- the cd's are 3-branes and the spool axis is the 4th orthogonal dimension). If each 3-brane could support a universe, then this construct would provide an example of parallel universes.
To answer your first question, the 'bulk' is the term used to describe the dimensions orthogonal to the brane of interest. The dimensionality depends on the model.
And a bit more here with some links:
http://en.wikipedia.org/wiki/Brane_cosmology
In general the bulk is not accessible, not observable, to us. In string theory, for example, forces such as the electromagnetic and nuclear forces are represented via vibrating strings whose ends are attached to branes...so they are 'stuck' in our three dimensional space.
Gravity, however, may be unattached strings which can "float" off into the bulk and it may be that is why it is so weak in our observable three dimensions of space...it diffuses into extra dimensions we can't so far observe. So one open question is whether the gravity from parallel universes might somehow be detectable in ours.
  • · Replies 18 ·
  • · Replies 0 ·
